• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Plant 3D
    Member
    Re: P3D 2012 ISOMETRICS
    09-29-2011 07:31 PM in reply to: kylepope
    Thank you Kyle, the snapshot helps.
    Karthik is away for couple of days, hence jumping in. Engine does not scale up the fittings and components (it uses the scale specified by the user). The reason why control station (marked in yellow below) is not spaced-out is because there are no pipes that can be geometrically stretched. All the components are connected to the fittings, hence the result. I would like to discuss this more with you, will contact you separately.
    -Murali
    Please use plain text.
    09-29-2011 07:41 PM in reply to: sraffe10
    Feel free to contact me anytime.
    KP
    Kyle Pope
    Process and Power Specialist
    ECAD, Inc
    Our Blog
    www.pdoteam.com
    Distinguished Contributor
    09-30-2011 01:26 PM in reply to: murali.p
    I read your thread with interest - wish I had seen it before I spent many hours "playing" with the set-ups. Anyway I still have a couple of set-up issues that I hope somebody can help me with - see attached PDF file.
    Thanks in advance
    Regards
    Gary
    10-03-2011 09:37 AM in reply to: MOLGRAND
    On the hatch scale, edit the ISOCONFIG.xml file, goto line 210 (or just do a find on the line of text HatchPatternScale ) and change the value there.
    I'll see what I can find on the other problems and let you know.
    KP
    Kyle Pope
    ECAD, Inc
    Our Blog
    www.pdoteam.com
    Valued Contributor
    pkw167
    10-03-2011 10:17 AM in reply to: MOLGRAND
    The problem with LDT info now showing on lines with multiple ISOs is a known problem with no solutions yet.
    this post covered it:
    http://forums.autodesk.com/t5/AutoCAD-Plant-3D/P3D-2012-Cutting-ISO-LDT-Bug/td-p/3159292
    Valued Contributor
    pkw167
    10-03-2011 10:18 AM in reply to: MOLGRAND
    on my last post, I ment "NOT" showing, not "NOW" showing... stupid edit function on this forum doesn't work
    10-09-2011 03:01 AM in reply to: murali.p
    Thanks for your info - what prog do you use to open it up (I have founf the file) - could you clarify please - I think I am missing something somewhere
    On the hatch scale, edit the ISOCONFIG.xml file, goto line 210 (or just do a find on the line of text HatchPatternScale ) and change the value -
    Gary
    10-10-2011 06:49 AM in reply to: MOLGRAND
    I use a product called TotalEdit, it's a free download from www.codertools.com.  You can also open the file up in notepad, but it has no formatting so it can be a little tricky to read.
    KP
    Kyle Pope
    ECAD, Inc
    Our Blog
    www.pdoteam.com
    10-11-2011 12:35 PM in reply to: murali.p
    Thanks that sorted out the hatch scaling a treat - I just need a few other answers on some other posts I did & Iwill be there on the Isos
    Regards
    Gary
