AutoCAD Plant 3D
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Re: P3D 2012: ISO setting problems
- Highlight
- Email to a Friend
Hi
Similar to this, I am having a problem configuring the ISO settings to refer to specific piping items.
Example: I have flexible hose couplings inside my spec, in the previous ISO settings, in the Spec Editor, I put the iso info as follows:
ISO TYPE: MISC-COMPONENT
ISO SKEY: FXSW
How do I go about mapping the new symbols to these existing items?
Or how would I choose a specific block to be placed when the ISO TYPE and SKEY are as what I have mentioned above?
Thanks!
- Highlight
- Email to a Friend
Title block & display page in Project Setup, Click Edit isometric Symbols... to create a symbol and name it. remember to add ports for hose connector.
Go to install folder: \AutoCAD Plant 3D 2012 - English\ISOProjectTemplates
Open IsoSkeyACADBlockMap.xml, add your skey and block name into it.
Create Iso.
Autodesk Plant Solutions
- Highlight
- Email to a Friend
Thanks Vicky
Will try it out...
- Highlight
- Email to a Friend
One small addition.
Please edit the IsoSkeyACADBlockMap.xml file in the project that you are going to add the new isometric symbols.
That is, open IsoSkeyACADBlockMap.xm in say C:\Users\<username>\Documents\MyNewProject\Isometr
You can also update the files (the IsoSymbolStyles.dwg and the IsoSkeyACADBlockMap.xml) in the install folder (\AutoCAD Plant 3D 2012 - English\ISOProjectTemplates) if you want *every* new project, in the given unit system, created from there on to have the new symbols and skeys.
If you want only the current working project to have the new skey support, please update only the project files.
HTH.
Ratti.
- Highlight
- Email to a Friend
Ratti is correct. Try to modify all the files in project folder not install folder.
