• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Plant 3D
    Valued Mentor
    dennis
    Accepted Solution
    P3D 2012 - File Name Format
    237 Views, 1 Replies
    08-09-2012 12:31 PM
    I want to do something a little different than what the default interface seems to be able to do for File Name Format.  I want to concantenate different data: Project Number - DWGType - DWGNumber - Sequence Number where Project Number is the same number entered on the Project Details, DWGType is a list of letters <example; D=PID, A=Architectural, I=Iso., and DWGNumber is the same as the number added in on the Properties of the DWG itself, Sequence is just user entry numbers <001, 002, etc>.  And here is the kicker, I only want to put this data in once.  I can get it to do what I want provided I am willing to fill out the info twice.
    So, is there a way to create a field in P3D File Name Format that will concatenate other fields together to produce the name I am after?
    Please use plain text.
    Product Support
    Re: P3D 2012 - File Name Format
    09-04-2012 02:02 AM in reply to: dennis
    Hi Dennis,
    You can use the command PLANTDEFINECALCPROPERTIES to combine properties.
    I have not tested using it to create a file name format as it is an undocumented and unsupported command so you will really need to try it yourself.
    Hope this helps.
    Dan
    Dan Scales
    Product Support Specialist
    Autodesk, Inc.
