• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Plant 3D
    Overview of total pipe length for pump selection
    294 Views, 6 Replies
    10-23-2012 11:59 PM
    Is there a way to make a selection or just point a linenumber and show me the length of the pipe? The purpose of this is to select pumps so we need to know the total length of the pipe including the amount of bends and fittings.
    Please use plain text.
    Product Support
    Re: Overview of total pipe length for pump selection
    10-31-2012 10:36 AM in reply to: snijdam
    Currently it is not possible to get a total length of a pipe run by selecting the entire line number.
    I will log an product enhancement request with our development team.
    Dan
    Dan Scales
    Product Support Specialist
    Autodesk, Inc.
    Distinguished Contributor
    Ahmed1081975
    10-31-2012 12:29 PM in reply to: snijdam
    I would Like To add also when select the pipe to show also length and coordinate
    And level it's very important CadWorx
    Programs have these issues
    Ahmed Helal
    Valued Mentor
    Rich.O.3d
    10-31-2012 04:15 PM in reply to: snijdam
    generaly preliminary pump selection and line size is done simply with the known approximation of differnece in head (discharge head - feed head) for the pumps duty and an approximation of total length
    then once the prelimnary design and routing of the pipe is done, either a pcf is sent to a pipe analyst for an accurate second pass
    If these calcs are done manualy, then i create an iso style such as 'pumpcalc' if you force this iso onto one sheet and only show pipe run components (pipe, elbows etc but not supports) this iso will give the full length in the bom and a qty of elbows, valves, orifice plates, etc for pressure loss factors. this iso will also give you the discharge head
    CAD Management 101:
    You can do it your own way,
    If its done just how I say!
    [Metallica:And Justice For All:1988]
    Active Contributor
    phwatso
    11-06-2012 08:39 AM in reply to: snijdam
    You can select the required pipe run and then use quickiso to create a parts list of fittings and pipe length, the advanced tab allows you to export the BoM into excel.
    11-06-2012 11:26 PM in reply to: phwatso
    That is not a sloution but a time taking workaround. I would like to see a summary in the data manager for example.
    Product Support
    11-07-2012 01:10 AM in reply to: snijdam
    The suggestions offered are indeed workarounds and for the time being they are the best option.
    The feature enhancement I have logged with our developers is to get a total pipe length from a simple selection of a pipe run.
    Dan
    Dan Scales
    Autodesk, Inc.
