I've upgraded to Extention 1 and running into a new problem. When I try to create a ortho view, nothing is being generated. The list comes up like it is generating something, but nothing ends up in the viewport (or model space). All the layers are turned on. I went back to an old project that I had previously done an ortho view on. If I update the view, everything disappears.
This is happening on two machines. Any help? Thanks.
Is it the problem listed in the readme?
I also encountered the same problem after installing Autodesk's AutoCAD Plant3d 2014 Extension 1. When I open a project created before the Extension pack 1 was installed and I do an Update View in the ortho View, everything disappears from the screen. All items in the viewport I try to update is gone ! Only the ortho annotations are still visible in Pspace.
I had 15 ortho views and all have the same problem !
After de-installing the extension pack 1 and re-installing Plant 3D, everything works out fine again !
Can you check this out ?
Marc
This message thread might pertain to the issue.
