• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Plant 3D
    Active Contributor
    phwatso
    Accepted Solution
    Orthographic Drawings
    491 Views, 10 Replies
    09-07-2012 03:10 AM
    When we use PLANTEQUIPMENTCONVERT to create equipment from AutoCAD XREFs the equipment does not display in the Orthographic drawings created.
    Please use plain text.
    Employee
    Re: Orthographic Drawings
    09-08-2012 11:04 PM in reply to: phwatso
    You have to make the original file part of the project. Right mouse click on the folder in the project manager and select "Copy Drawing to Project". Then xref from there.
    If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
    Jarrod Mudford
    Plant Solutions Consultant
    Global Services
    Autodesk, Inc.
    Distinguished Contributor
    Arun_Kumar_K
    09-13-2012 03:57 AM in reply to: JarrodMudford
    Even after you make xref from the project file, the orthographic will not be displayed.
    If you XREF, orthographic will not be generated even if it is in project file.
    I find its a bug of the software, tried several times.
    Product Support
    09-13-2012 04:37 AM in reply to: phwatso
    If I convert AutoCAD objects using PLANTEQUIPMENTCONVERT and then the drawing is xreffed into another drawing I can create an Ortho that included the Xref equipment.
    I tested this in Plant 2013, is that the version that you are using?
    Dan
    Dan Scales
    Product Support Specialist
    Autodesk, Inc.
    Active Contributor
    Jorgen1990
    09-13-2012 06:21 AM in reply to: phwatso
    Is your file XREF-ed as an overlay or as an attachment? Overlays won't show on orthos, attachments will.
    Jörgen
    Product Support
    09-13-2012 06:29 AM in reply to: Jorgen1990
    Yes, it looks like overlayed Xrefs are the issue. Attached Xrefs work fine.
    I believe that this has logged with our developers already.
    Dan
    Dan Scales
    Autodesk, Inc.
    Arun_Kumar_K
    09-13-2012 11:01 PM in reply to: DanScales
    Yes, attachment in overlay only causing problems.
    Arun_Kumar_K
    09-13-2012 11:05 PM in reply to: Arun_Kumar_K
    Also, there is an issue in Orthographic. If i take the drawings from ASD, the ortho views are not proper. Already we logged this bug with development team. Hope it will be resoved in 2014 release. Because of this interfacing issue, we are not able to use the ASD and Revit.
    Active Contributor
    phwatso
    09-18-2012 03:48 AM in reply to: phwatso
    We Xref (attach) a part (grundfos pump model for example) into our piping model and then use plantequipmentconvert in the piping model to add nozzle information etc.
    Which order/process should we be using to ensure they display in orthographic drawings?
    Sorry for the delay in responding...
    Active Contributor
    Jorgen1990
    09-24-2012 02:09 AM in reply to: DanScales
    Dan
    Hi
    By my understanding, it is not an issue or a problem. Overlays are not supposed to show on orthos. If you want to see xref-s on orthos, insert them as attachments. The idea of overlay is that you can see the xref while working in your file and use it as a guidance, but leave it out of orthos.
    Cheers,
    Jörgen
