AutoCAD Plant 3D
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Ortho creation in Plant 3D with revit dwg exported background s
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
323 Views, 4 Replies
01-24-2012 07:19 AM
We are currently working with AutoCAD Plant 3D 2012. All pipe routing we are doing with plant, but structural, architectural and General Arrangment models are being done in revit. The problem I am having is that the Revit DWG exports are huge files (about 75mb to 300mb) are causing ortho creation to take anywhere from 20 to 40 minutes per view. Can I export a revit file to a more compressed format or am I just doing something wrong? Any ideas would be appreciated.
Re: Ortho creation in Plant 3D with revit dwg exported background s
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
01-24-2012 08:42 AM in reply to:
KBKerstetter
Have you played with the setup options under Export > DWG Setups?
Dave Wolfe
Isaiah 57:15
ECAD, Inc.
Tips and Tricks on our blog: Process Design, from the Outside
A P3D Authorized Reseller
Isaiah 57:15
ECAD, Inc.
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
01-24-2012 08:45 AM in reply to:
dave.wolfe
Yes... I am currently experimenting with exporting down to 07 and 04 formats to see if it makes the files more manageable for plant.
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
01-24-2012 09:01 AM in reply to:
KBKerstetter
See if using Arch objects works for you. I was able to produce an ortho with the Arch Objects included, and the files are much smaller.
Dave Wolfe
Isaiah 57:15
ECAD, Inc.
Isaiah 57:15
ECAD, Inc.
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
07-30-2012 01:07 PM in reply to:
dave.wolfe
Dave,
The files were indeed smaller (33 mb for ACIS versus 10 mb for ACAD Arch objects). The problem is that my resultant dwg is all messed up (see pictures attached).
The first is the ACIS (which is what i see in Revit) and the second is the ACAD Objects (messed up).
Any ideas on what's causing this?
I'm using both AutoCAD Plant 3D and Revit Arc/Str/MEP 2012 versions.
PS: Both work fine when creating an Ortho View
