• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD Plant 3D
    Valued Mentor
    JohnHolder
    Ortho Issues
    238 Views, 6 Replies
    10-17-2012 04:31 PM
    Another problem....
    I have 6 sections of a site.
    If I xref them into one drawing ( attachment ) so I can do a single Ortho of the entire site it causes a fatal error
    if I do an ortho of each site individually - no fatal error.
    if I ortho A B C D together - no fatal error
    if I add E or F - fatal error
    if I ortho E and F - no fatal error  *edit* Recover = no errors on all drawings, audit project = no errors in project
    cleared graphical cache
    there is no data cache
    reciently repaired, re-installed, uninstalled then re-installed.
    What I had to do, is ortho each area individually on the same page, then scale them and <move> them so they sat properly. - crappy work around but it sort of works.
    Now the client wants me to rearrange 2 systems and a room.....
    I open up one of the systems and attempt to move it and machine locks up
    simple window selection ( aprox 1500 objects )  takes 30 seconds to recognize I have selected everything
    then when I attempt to <move> it locks, basically waits an inane amount of time then does nothing.
    I do realize selecting a large group of pipes and equipment can cause a delay - I have done this with 5 to 7000 objects and it takes less time ( which are vastly more complicated )
    I am running out of patience.  I must be doing something fundamentally wrong.
    Any suggestions? ( at least 20 error reports in today )
    PS - i really really do not want to redo ALL the piping on this project *again*
    An education isn't how much you have committed to memory, or even how much you know. It's being able to differentiate between what you know and what you don't.
    "Do or do not... there is no try"
    Master Yoda.
    Please use plain text.
    *Expert Elite*
    dave.wolfe
    Re: Ortho Issues
    10-18-2012 05:03 AM in reply to: JohnHolder
    Did you try this?
    http://www.pdoteam.com/2012/07/large-model-orthos/
    Dave Wolfe
    Isaiah 57:15
    ECAD, Inc.
    Tips and Tricks on our blog: Process Design, from the Outside
    A P3D Authorized Reseller
    Valued Mentor
    JohnHolder
    Re: Ortho Issues
    10-18-2012 09:10 AM in reply to: dave.wolfe
    It crashes on the <Preparing orthographic output> stage only.
    I just tested that, and opening in shaded has never been an issue, even in much larger projects.
    Master Yoda.
    *Expert Elite*
    dave.wolfe
    Re: Ortho Issues
    10-18-2012 10:44 AM in reply to: JohnHolder
    Have you tried without attaching them all as xrefs?  I don't think the ortho routine is xref dependent. So, as long as you choose the models to include, you should be able to skip the attachment part.
    Dave Wolfe
    Isaiah 57:15
    ECAD, Inc.
    Valued Mentor
    JohnHolder
    Re: Ortho Issues
    10-18-2012 11:14 AM in reply to: dave.wolfe
    Takes an inane amount of time then crashes.
    I think there is an undetectable error in larval upweller drawing, since I cannot move any of the piping in the drawing.
    I think it is down to deleting it and redoing that part and see if that does it
    John.
    Master Yoda.
    *Expert Elite*
    dave.wolfe
    Re: Ortho Issues
    10-18-2012 11:20 AM in reply to: JohnHolder
    Have you run AUDITPROJECT and PLANTAUDIT (backup first)?
    Dave Wolfe
    Isaiah 57:15
    ECAD, Inc.
    Valued Mentor
    JohnHolder
    Re: Ortho Issues
    10-18-2012 11:30 AM in reply to: dave.wolfe
    yeah fairly often, including trying to recover the drawings.  Always shows up with no errors.
    I just deleted all the piping in the drawing that I am unable to move and attempting a new orth of the full site.
    still crashes.
    Master Yoda.
