• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Plant 3D
    Active Contributor
    Objects loosing intelligence
    194 Views, 2 Replies
    03-28-2010 09:46 PM
    I am wondering if anyone has come across this or not where object in a 3D drawing loose its intelligence. I'm pretty sure it was because i copied in an updated spec but the parts that were different between the versions of the specs weren't modified.
    Is there a way to make it work again without reverting back to the previous spec (which i dont have anymore)?
    I'm still updating the specs and the project is only a test but it would be good to know if there is a work around or not and also so i dont do it again.
    I've attached a pic showing what it looks like when a part is selected and the properties window showing no info.
    Cheers,
    Scott
    Please use plain text.
    *Jorge Lopez
    Re: Objects loosing intelligence
    03-30-2010 11:59 AM in reply to: sreid13
    Hi Scott,
    I do not believe this is related to the specs. It appears the entity lost
    its link to the project database. The only way I know to fix this is to
    erase it and re-draw it. Are you working in a multi-user environment with a
    network project?
    Jorge
    "sreid13" wrote in message news:6362376@discussion.autodesk.com...
    again.
    Cheers,
    Scott
    Active Contributor
    03-30-2010 03:52 PM in reply to: sreid13
    Hi Jorge
    To erase and redraw is the only solution I have found also. The problem is it happens to the entire drawing so redrawing is quite painful but i have found reverting to an earlier autosave does restore it.
    It is a network Project but i should have been the only one modifing it. It has happened to other people here also so I'm not sure what is causing it.
    Scott
