AutoCAD Plant 3D
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Objects loosing intelligen ce
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
193 Views, 2 Replies
03-28-2010 09:46 PM
I am wondering if anyone has come across this or not where object in a 3D drawing loose its intelligence. I'm pretty sure it was because i copied in an updated spec but the parts that were different between the versions of the specs weren't modified.
Is there a way to make it work again without reverting back to the previous spec (which i dont have anymore)?
I'm still updating the specs and the project is only a test but it would be good to know if there is a work around or not and also so i dont do it again.
I've attached a pic showing what it looks like when a part is selected and the properties window showing no info.
Cheers,
Scott
Cheers,
Scott
*Jorge Lopez
Re: Objects loosing intelligen ce
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
03-30-2010 11:59 AM in reply to:
sreid13
Hi Scott,
I do not believe this is related to the specs. It appears the entity lost
its link to the project database. The only way I know to fix this is to
erase it and re-draw it. Are you working in a multi-user environment with a
network project?
Jorge
"sreid13" wrote in message news:6362376@discussion.autodesk.com...
again.
Cheers,
Scott
network project?
Jorge
again.
Cheers,
Scott
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
03-30-2010 03:52 PM in reply to:
sreid13
Hi Jorge
To erase and redraw is the only solution I have found also. The problem is it happens to the entire drawing so redrawing is quite painful but i have found reverting to an earlier autosave does restore it.
It is a network Project but i should have been the only one modifing it. It has happened to other people here also so I'm not sure what is causing it.
Scott
Scott
