• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Plant 3D
    Accepted Solution
    Objects Compatability w/ Vanilla AutoCAD
    145 Views, 3 Replies
    04-28-2012 03:09 PM
    Greetings All,
    Currently our pipers are using Bentley for their work but there has always been an issue for us plain vanilla AutoCAD users.  The Bentley Object Enabler allows us to see the work but we cannot edit them (copy, move, delete, etc.) and always have to pass them back to a piper.
    We are migrating over to Autoplant 3D in the near future however we're not buying a seat for everbody so the question I have is, are entities created by Autoplant 3D specific to it or can they be edited by someone who is using plain vanilla AutoCAD? Are Bentley Objects in current drawings editable with Autoplant 3D and/or is there some kind of a conversion process?
    Keith
    Please use plain text.
    Employee
    TomislavGolubovic
    Re: Objects Compatability w/ Vanilla AutoCAD
    04-28-2012 04:48 PM in reply to: Volk359
    AutoCAD users shouldn't be opening the models. You can install Object Enablers so they can see the elements, but ultimately, you can use the EXPORTTOAUTOCAD command on the models and dumb the models down to basic AutoCAD solids.
    Plant3D still needs specs and a database to work, so no, AutoCAD users can't (and shouldn't) be editing Plant3D models.
    Tomislav Golubovic
    Plant Solutions Engineer
    Autodesk Australia / New Zealand
    Autodesk, Inc.
    Employee
    05-01-2012 12:50 PM in reply to: TomislavGolubovic
    Tom is right.  You can open P3D models in ACAD even without installing the object enabler.  You will get proxy graphics and wont be able to see any meta data.  If you install the OE, you can see the meta data.  However, to edit the model, you will need P3D.
    Pat Jenakanandhini
    Product Manager
    Plant Solutions - AEC
    05-01-2012 02:46 PM in reply to: Volk359
    That gives me the heads up I needed, thanks much.
