AutoCAD Plant 3D
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Nominal Size
- Highlight
- Email to a Friend
Can you turn the NS off so that it does not come in when ISO's are created? BOM takes care of size so I don't want the NS on the drawings.
Re: Nominal Size
- Highlight
- Email to a Friend
Yes
Go to IsoConfig.xml and find <PropertyChangeScheme Name="Size" AnnotationStyle="Standard" Format="{0} NS" Grouping="true" Alignment="FlatHorizontal" LeaderStyle="AsNeeded" Filter="NotBoltWeldFlangeGasket" Field="Size" Placement="Along" />
Locate Format=“{0} NS” ,change the value of Format to Format=“ ”.
After modifing ,you will get <PropertyChangeScheme Name="Size" AnnotationStyle="Standard" Format=" " Grouping="true" Alignment="FlatHorizontal" LeaderStyle="AsNeeded" Filter="NotBoltWeldFlangeGasket" Field="Size" Placement="Along" />
Close and save the IsoConfig.xml, and create isometric again, you will get isometris drawing without NS shown
Re: Nominal Size
- Highlight
- Email to a Friend
Thank you!![]()
Re: Nominal Size
- Highlight
- Email to a Friend
Is posible to change it to mm (in default configuration is inch)?
Yury Bogdanov
ASIDEK(Grupo CT)
Barcelona (Spain)
