• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Plant 3D
    Distinguished Contributor
    PatrickByrne
    No Plant 3D Properties in Navisworks
    382 Views, 3 Replies
    11-12-2012 05:07 PM
    I must be doing something wrong.
    When I click on a Plant 3D object in Navisworks 2013 there is no useful information except source file and layer. When I click on a CadWorx pipe item I get Short Description, Size, Long Description, Tag, Line number, Specification, Database code, Weight and Length.
    Since Plant 3D and Navisworks are Autodesk products can somebody confirm this pipe information is also available for Plant 3D objects we will then know it is our setup
    Please use plain text.
    dave.wolfe
    Re: No Plant 3D Properties in Navisworks
    11-12-2012 05:41 PM in reply to: PatrickByrne
    Are your object enabler's installed for Navisworks?
    Dave Wolfe
    Isaiah 57:15
    ECAD, Inc.
    Tips and Tricks on our blog: Process Design, from the Outside
    A P3D Authorized Reseller
    PatrickByrne
    11-12-2012 06:20 PM in reply to: dave.wolfe
    Hi Dave,
    We had the object enabler installed, but I had not restarted the machine. It looks good now. Thanks
    PatrickByrne
    11-12-2012 07:18 PM in reply to: PatrickByrne
    Further to above, we had the 2012 object enabler installed to match 2012 Plant 3D, we needed to install the 2013 object enabler to match 2013 Navisworks.
