• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Plant 3D
    Board Manager
    EileenForan
    New hot fixes available now
    1455 Views, 1 Replies
    07-20-2012 08:55 AM
    The following two hot fixes are available for the specific languages mentioned below. The hotfixes are released for AutoCAD Plant3D 2013.
    AutoCAD Plant 3D 2013 Custom Parts Builder Hotfix
    This hotfix applies to AutoCAD Plant 3D 2013. JPN, FRA, CHS, RUS.
    http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=20089556&linkID=14116968
    Correct a problem that inch value displays with metric unit in the “Custom Parts Builder” palette.
    AutoCAD Plant 3D 2013 Plantpipeadd command Hotfix
    This hotfix applies to AutoCAD Plant 3D 2013. CHS, DEU, RUS.
    http://usa.autodesk.com/adsk/servlet/ps/dl/item?id=20087000&siteID=123112&linkID=14116968
    Correct a problem that the options of the ‘_Plantpipeadd’ command are not responsive in command line.
    Eileen
    Eileen Foran
    Community Program Manager
    Autodesk Plant Solutions
    Please use plain text.
    Member
    Re: New hot fixes available now
    11-21-2012 09:28 AM in reply to: EileenForan
     just downloaded and installed the "AutoCAD Plant 3D 2013 off-page connector hot-fix.  Then I go to reload a project that I had just been working in.   and now I get the message, "failed to load project file."and nothing shows up.   Can anyone please tell me what I am doing wrong?  Has anyone else had this problem?
    tHANKS
