• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Plant 3D
    HermannSemlitsch5177
    New Connection Type in Project setup for Laminations (GRP)
    293 Views, 5 Replies
    08-24-2012 01:18 AM
    hi,
    how i can add a new connection type in the project setup?
    because the Pipe material is Glass Reinforced Plastic and the have laminations instead of welds. for this i need a new connection Parts in 3D ( example see attached file) and something in Isometrics (Description in the Weld list / Symbols / ......)......
    thanks
    Hermann
    Please use plain text.
    Employee
    TomislavGolubovic
    Re: New Connection Type in Project setup for Laminations (GRP)
    08-26-2012 03:27 PM in reply to: HermannSemlitsch5177
    In Plant3D, type PLANTENDCODES and you can add new end codes. In the Catalog and Spec editor, you can manually type in the same End Codes in the parts editor to match the new ones you just created.
    In the Project Properties, have a look at the Piping Connection Settings and add your new connections to the list with whichever fasteners it requires.
    Tomislav Golubovic
    Plant Solutions Engineer
    Autodesk Australia / New Zealand
    Autodesk, Inc.
    08-27-2012 08:40 AM in reply to: TomislavGolubovic
    thanks, but i know this stuff with the endcodes. i want to add a complette new connection Type in to the system. how i can make this because this will effect a lot (3D, 2D, Isos)
    i attached files for example what i mean.
    thanks
    Employee
    TomislavGolubovic
    08-27-2012 04:32 PM in reply to: HermannSemlitsch5177
    ah ok, gimme a sec
    Tomislav Golubovic
    Autodesk, Inc.
    Active Contributor
    vannmannen
    12-05-2012 06:10 PM in reply to: TomislavGolubovic
    Having GRP issues aswell. Did anyone look into this?
    12-05-2012 08:34 PM in reply to: vannmannen
    hi,vannmannen
    i have recieved some emails according to this.
    they told me that this is at the moment not possible to add a new connection type but they will note this in the develeopment.
    the only way is to change one of the existing connection types(not used) into this what you need.
