• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Plant 3D
    Member
    Modification Nozzles
    227 Views, 4 Replies
    09-10-2012 08:19 AM
    I'm inserting equipment (tanks) and I get the nozzle with a flange type WN.
    How can you change the type of nozzle flange SLIP-ON?
    Please use plain text.
    Ahmed1081975
    Re: Modification Nozzles
    09-10-2012 01:09 PM in reply to: jmiguell
    You have to Add First in Your Spec File and it will be a bear in Edite Nozzle
    Ahmed Helal
    Member
    09-11-2012 07:53 AM in reply to: Ahmed1081975
    I could send the steps to add the Nozzles to spec
    thanks
    Ahmed1081975
    09-11-2012 09:44 AM in reply to: jmiguell
    Here you are in the attached files
    Ahmed Helal
    Valued Mentor
    Rich.O.3d
    09-11-2012 03:15 PM in reply to: jmiguell
    in 2012 you may need to edit the file 'NOZZLE Catalogue.acat'
    it will be under your 'CPak Common' folder
    in the catalogue editor, when you go to the open dialogue box, just pick the *.acat from the 'files of type' drop down box.
    CAD Management 101:
    You can do it your own way,
    If its done just how I say!
    [Metallica:And Justice For All:1988]
