• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Plant 3D
    Employee
    rajsekarpillai
    Re: Modeling up custom fittings
    05-21-2012 08:25 PM in reply to: JohnHolder
    Just want to confirm with you that your new partfamily is on right class hierarchy? It should be “Olet” class and subclass should be “Weldolet” or “Sockolet”.
    Please pass your excel sheet or snap shot, I will look into it.
    Thanks & Regards,
    S. R. Rajasekaran
    Product Manager
    Plant Solutions - AEC
    Autodesk, Inc.
    Please use plain text.
    Valued Mentor
    JohnHolder
    05-22-2012 09:58 AM in reply to: rajsekarpillai
    I do not see a subclass area.
    I am not using excel, just the AutoCAD Plant 3D Spec Editor 2013
    An education isn't how much you have committed to memory, or even how much you know. It's being able to differentiate between what you know and what you don't.
    "Do or do not... there is no try"
    Master Yoda.
    Valued Contributor
    Arch_art
    09-26-2012 03:35 PM in reply to: rajsekarpillai
    I have successfully create the saddle. Problem is, it doesn't recognize the flow of the pipe. How can I let it behave like pipe support? Pipe support only one connection point on pipe run, but still recognize the direction of the pipe run. Look at the image.(I like the one on left knows the flow of pipe and insert it like the one on right.)
    Cheers,
    Peggy
    Valued Contributor
    Arch_art
    09-26-2012 03:36 PM in reply to: JohnHolder
    Hi, John
    Have you find the answer?
    Cheers,
    Peggy
    Valued Contributor
    Arch_art
    09-26-2012 06:43 PM in reply to: rajsekarpillai
    No worries. I got it to work now.
    When create the block, just need to make sure the direction you want to match the pipe is parrallel with X axil. If it is match with X, the pipe run will be correct.
    Am I right? Or I am just accidently correct? Please confirm.
    Cheers
    Peggy
    Valued Contributor
    Arch_art
    09-26-2012 06:44 PM in reply to: JohnHolder
    Hi, John
    I found it, the subtyle is in the General Properties tab after you created the component. Not when you create the component.
    Cheers,
    Peggy
