09:02 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have created two specs with components that I have created following the instructions from these autodesk videos:
Specs and Catalogs Editor in AutoCAD Plant 3D (Part 1)
Specs and Catalogs Editor in AutoCAD Plant 3D (Part 2)
The long description family name appears correctly inside the spec, but once I generate my ISO, the material part doesn't appear... when I look into the properties of the item inside my spec, the material only appears on the "long description(family)" and not on the "long description (size)". How do I get the material in there without needing to manually edit each componenet and size.
