AutoCAD Plant 3D
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Made the mistake of downgradin g from windows 7 to windows 8....
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
everytime I try to use Quickproperties
I get an error
"Microsoft .NET Framework
Unhandled exception has occured in a component in your application.
If you click Continue, the application will ignore this error and attempt to continue.
Object reference not set to an instance of an object."
I am just trying to get everything reset since Windows 8 completely messed up everything and I had to reinstall autocad ( yet again - and re-authorize ) wiped everything off the computer since I had to "freshen" up windows 8 ( try to avoid this at all costs ) and basically waste a day...*sigh*
Now I am getting lots of little errors..
Oh if you use windows gadgets ( which I do on a daily basis ) I would avoid Windows 8.. hell if you work or play I'd avoid windows 8...
just avoid it. Microsoft continues their tradition of a good OS followed by a complete waste of time OS ( windows 8 )
but back to the original problem - QP does not work anymore for me, and apparently .NET is upto date.
any suggestions... ( I am going to attempt to try windows 8 )
DETAILS of error message follows
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.NullReferenceException: Object reference not set to an instance of an object.
at Autodesk.AutoCAD.Customization.quickPropertyContro
at Autodesk.AutoCAD.Customization.MainForm.FindAndSel
at Autodesk.AutoCAD.Customization.MainForm.SelectQPNo
at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
at System.Windows.Forms.Control.CreateControl()
at System.Windows.Forms.Control.WmShowWindow(Message& m)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.Form.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 4.0.0.0
Win32 Version: 4.0.30319.17929 built by: FX45RTMREL
CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v4.0.
Acdbmgd
Assembly Version: 19.0.0.0
Win32 Version: 19.0.55.0.0
CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plan
System
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL
System.Core
AdApplicationFrame
Assembly Version: 0.0.0.0
Win32 Version: 3.5.19.0
AdWindows
Assembly Version: 3.5.21.0
Win32 Version: 3.5.21.0
PresentationFramework
WindowsBase
PresentationCore
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_64/P
System.Xaml
System.Xml
PresentationFramework.Aero2
System.Drawing
accoremgd
Acmgd
System.Configuration
AcWindows
AcCui
PresentationFramework-SystemXml
WindowsFormsIntegration
AcWindows.resources
PresentationUI
System.Xml.Linq
PresentationFramework-SystemXmlLinq
AcFusion
Assembly Version: 1.0.4413.25343
Win32 Version: 0.2.0.230
CodeBase: file:///c:/program%20files/autodesk/applicationplu
AcFusionRes
Assembly Version: 0.2.0.230
CodeBase: file:///C:/Program%20Files/Autodesk/ApplicationPlu
PnPDataLinks
Win32 Version: 4.0.26.00
PnPCommonArx
PnPProjectManager
PnPProjectManagerMgd
Assembly Version: 4.0.26.0
PnPCommonMgd
PnIDMgdInternal
PnIDUIMgd
PnPCIP
PnIDCIP
PnP3dContentMgd
PnPUtilMgd
PnP3dMain
PnP3dSpecUI
PnP3dSpecUI.resources
PnPProjectManagerUI
PnPProjectManagerUI.resources
PnPRevisionCloud
XDbReferenceManagerArx
XDbReferenceManagerArx.resources
PnIDMain
CodeBase: file:///c:/program%20files/autodesk/autocad%20plan
ContextualTabSelectorRules
PnP3dWorkspace
PnP3dWorkspace.resources
PnP3dCustomControlLibrary
PnP3dOrthoDrawingsUI
PnPDwg2dUtil
PnPDwg2dAnno
PnPDwg2dDbx
PnP3dOrthoDrawingsUI.resources
PnPDwg2dDef
Win32 Version:
PnP3dIsoUI
AliasRibbonUI
Assembly Version: 19.0.55.0
AliasUnderlayRibbonUI
Assembly Version: 1.0.4427.22204
ManagedMC3
Assembly Version: 6.4.0.0
Win32 Version: 6.4.0.0
PresentationFramework-SystemCore
UIAutomationTypes
PnPDataObjects
Assembly Version: 1.0.4436.40546
Accessibility
Autodesk.AutoCAD.Interop
Autodesk.AutoCAD.Interop.Common
PnP3dProjectPartsMgd
Microsoft.GeneratedCode
Assembly Version: 1.0.0.0
PnIDProjectPartsMgd
PnP3dConnectionManager
PnP3dPartsRepository
PnP3dDataLinkManager
PnP3dOrthoProjectPart
System.Data
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_64/S
PnPSQLiteEngine
Assembly Version: 1.0.4436.40554
System.Data.SQLite
Assembly Version: 1.0.65.0
Win32 Version: 1.0.65.0
System.Transactions
Microsoft.VisualC
Assembly Version: 10.0.0.0
Win32 Version: 11.00.50709.17929 built by: FX45RTMREL
System.EnterpriseServices
System.Numerics
PnIDProjectParts
PnIdGuiUtils
PnIDGUIUtilMgd
PnP3dProjectParts
PnP3dPipeRoutingUI
PnP3dPipeRoutingUI.resources
PnP3dSpecManager
PnPCommonUIMgdCs
PnP3dPlantContentUpgrade
PnP3dProjectManagerUI
PnPIsoCore
Assembly Version: 2.0.24.0
Win32 Version: 2.0.24.00
PnP3dProjectManagerUI.resources
PnPCommonUIMgd
PresentationFramework-SystemData
PnPWelcomeManager
AcLivePreviewContext
PnP3dObjects
PnP3dPipeUI
PnPValidation
PnIDDwgValidation
PnIDDwgValidation.resources
PnIDWorkspace
AcLayer
AcLayer.resources
PresentationFramework.Luna
AcMrUi
AcMrUi.resources
AcMr
System.Runtime.Serialization
UIAutomationProvider
PnPDataGrid
PnPDataGrid.resources
PnP3dObjectsMgd
PnP3dACPUtils
AcCustomize
AcCustomize.resources
System.Design
AcCommandToolTips
AcCommandToolTips.resources
AcDialogToolTips
AcDialogToolTips.resources
PnP3dEquipmentUI
PnP3dCommonUIMgd
PnPCommonDbxMgd
PnP3dEquipmentUI.resources
PnP3dUIUtilsMgd
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
"Do or do not... there is no try"
Master Yoda.
Re: Made the mistake of downgradin g from windows 7 to windows 8....
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
i was wondering if someone was going to have a crack at the win8 'downgrade' (lol)
the word I hear is DONT BOTHER unless you have a tablet
Its microsofts first attempt at a full blown app driven touchscreen style OS so ill probably be sticking with win7 for the next couple of windows releases
You can do it your own way,
If its done just how I say!
[Metallica:And Justice For All:1988]
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Firstly.......check if the AutoCAD versions are supported on Windows 8.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?si
Answer....not yet.
Jarrod Mudford
Plant Solutions Consultant
Global Services
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Besides the normal slew of errors Autocad has that pop up constaintly...
Windows 8 still sucks and and is a bad idea IMO for anyone who works with a computer to use.
Expecially with duel monitor... that is where Windows 8 really sucks.
Master Yoda.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
And this is based on... what? Running software which isn't compatible?
Adopt. Adapt. Overcome. Or be overcome.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Yes I realize I jumped the gun a little quick. After using it for a few days on my laptop with no issues.
Master Yoda.
