• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Plant 3D
    Valued Mentor
    JohnHolder
    Accepted Solution
    Made the mistake of downgrading from windows 7 to windows 8....
    498 Views, 5 Replies
    11-01-2012 02:12 PM
    everytime I try to use Quickproperties
    I get an error
    "Microsoft .NET Framework
    Unhandled exception has occured in a component in your application.
    If you click Continue, the application will ignore this error and attempt to continue.
    Object reference not set to an instance of an object."
    I am just trying to get everything reset since Windows 8 completely messed up everything and I had to reinstall autocad ( yet again - and re-authorize ) wiped everything off the computer since I had to "freshen" up windows 8 ( try to avoid this at all costs ) and basically waste a day...*sigh*
    Now I am getting lots of little errors..
    Oh if you use windows gadgets ( which I do on a daily basis ) I would avoid Windows 8.. hell if you work or play I'd avoid windows 8...
    just avoid it.  Microsoft continues their tradition of a good OS followed by a complete waste of time OS ( windows 8 )
    but back to the original problem - QP does not work anymore for me, and apparently .NET is upto date.
    any suggestions... ( I am going to attempt to try windows 8 )
    DETAILS of error message follows
    See the end of this message for details on invoking
    just-in-time (JIT) debugging instead of this dialog box.
    ************** Exception Text **************
    System.NullReferenceException: Object reference not set to an instance of an object.
    at Autodesk.AutoCAD.Customization.quickPropertyControl.set_IsRolloverToolTip(Boolean value)
    at Autodesk.AutoCAD.Customization.quickPropertyControl.populateFromAllCuiFiles(Boolean bRolloverTooltips)
    at Autodesk.AutoCAD.Customization.MainForm.FindAndSelectTreeNodeRecursive(CUITreeNode treeNode)
    at Autodesk.AutoCAD.Customization.MainForm.SelectQPNodeForTheObjectType()
    at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
    at System.Windows.Forms.Control.CreateControl()
    at System.Windows.Forms.Control.WmShowWindow(Message& m)
    at System.Windows.Forms.Control.WndProc(Message& m)
    at System.Windows.Forms.Form.WndProc(Message& m)
    at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
    ************** Loaded Assemblies **************
    mscorlib
    Assembly Version: 4.0.0.0
    Win32 Version: 4.0.30319.17929 built by: FX45RTMREL
    CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll
    Acdbmgd
    Assembly Version: 19.0.0.0
    Win32 Version: 19.0.55.0.0
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/AcdbMgd.DLL
    System
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
    System.Core
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
    AdApplicationFrame
    Assembly Version: 0.0.0.0
    Win32 Version: 3.5.19.0
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/AdApplicationFrame.DLL
    AdWindows
    Assembly Version: 3.5.21.0
    Win32 Version: 3.5.21.0
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/AdWindows.DLL
    PresentationFramework
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.dll
    WindowsBase
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/WindowsBase/v4.0_4.0.0.0__31bf3856ad364e35/WindowsBase.dll
    PresentationCore
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_64/PresentationCore/v4.0_4.0.0.0__31bf3856ad364e35/PresentationCore.dll
    System.Xaml
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xaml/v4.0_4.0.0.0__b77a5c561934e089/System.Xaml.dll
    System.Xml
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
    PresentationFramework.Aero2
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework.Aero2/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.Aero2.dll
    System.Drawing
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
    accoremgd
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/accoremgd.DLL
    Acmgd
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/Acmgd.DLL
    System.Configuration
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
    AcWindows
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/AcWindows.DLL
    AcCui
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/AcCui.DLL
    PresentationFramework-SystemXml
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemXml/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemXml.dll
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework.Aero/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.Aero.dll
    WindowsFormsIntegration
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/WindowsFormsIntegration/v4.0_4.0.0.0__31bf3856ad364e35/WindowsFormsIntegration.dll
    AcWindows.resources
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/en-US/AcWindows.resources.DLL
    PresentationUI
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationUI/v4.0_4.0.0.0__31bf3856ad364e35/PresentationUI.dll
    System.Xml.Linq
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml.Linq/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.Linq.dll
    PresentationFramework-SystemXmlLinq
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemXmlLinq/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemXmlLinq.dll
    AcFusion
    Assembly Version: 1.0.4413.25343
    Win32 Version: 0.2.0.230
    CodeBase: file:///c:/program%20files/autodesk/applicationplugins/fusionplugin2013.bundle/contents/win64/acfusion.arx
    AcFusionRes
    Assembly Version: 0.2.0.230
    CodeBase: file:///C:/Program%20Files/Autodesk/ApplicationPlugins/FusionPlugin2013.bundle/Contents/Win64/AcFusionRes.dll
    PnPDataLinks
    Win32 Version: 4.0.26.00
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/PnPDataLinks.DLL
    PnPCommonArx
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/pnpcommonarx.arx
    PnPProjectManager
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/PnPProjectManager.arx
    PnPProjectManagerMgd
    Assembly Version: 4.0.26.0
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/PnPProjectManagerMgd.DLL
    PnPCommonMgd
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/PnPCommonMgd.DLL
    PnIDMgdInternal
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/PnIDMgdInternal.DLL
    PnIDUIMgd
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/PnIDUIMgd.DLL
    PnPCIP
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/PnPCIP.DLL
    PnIDCIP
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/PnIDCIP.DLL
    PnP3dContentMgd
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/PnP3dContentMgd.DLL
    PnPUtilMgd
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/PnPUtilMgd.DLL
    PnP3dMain
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/PnP3dMain.DLL
    PnP3dSpecUI
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/PnP3dSpecUI.DLL
    PnP3dSpecUI.resources
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/en-US/PnP3dSpecUI.resources.DLL
    PnPProjectManagerUI
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/PnPProjectManagerUI.DLL
    PnPProjectManagerUI.resources
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/en-US/PnPProjectManagerUI.resources.DLL
    PnPRevisionCloud
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/PnPRevisionCloud.DLL
    XDbReferenceManagerArx
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/XDbReferenceManagerArx.DLL
    XDbReferenceManagerArx.resources
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/en-US/XDbReferenceManagerArx.resources.DLL
    PnIDMain
    CodeBase: file:///c:/program%20files/autodesk/autocad%20plant%203d%202013%20-%20english/pnidmain.arx
    ContextualTabSelectorRules
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/AcWindows.dll
    PnP3dWorkspace
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/PnP3dWorkspace.DLL
    PnP3dWorkspace.resources
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/en-US/PnP3dWorkspace.resources.DLL
    PnP3dCustomControlLibrary
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/PnP3dCustomControlLibrary.DLL
    PnP3dOrthoDrawingsUI
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/PnP3dOrthoDrawingsUI.DLL
    PnPDwg2dUtil
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/PnPDwg2dUtil.DLL
    PnPDwg2dAnno
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/PnPDwg2dAnno.DLL
    PnPDwg2dDbx
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/PnPDwg2dDbx.DLL
    PnP3dOrthoDrawingsUI.resources
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/en-US/PnP3dOrthoDrawingsUI.resources.DLL
    PnPDwg2dDef
    Win32 Version:
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/PnPDwg2dDef.DLL
    PnP3dIsoUI
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/PnP3dIsoUI.DLL
    AliasRibbonUI
    Assembly Version: 19.0.55.0
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/AliasRibbonUI.DLL
    AliasUnderlayRibbonUI
    Assembly Version: 1.0.4427.22204
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/AliasUnderlayRibbonUI.DLL
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
    ManagedMC3
    Assembly Version: 6.4.0.0
    Win32 Version: 6.4.0.0
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/ManagedMC3.DLL
    PresentationFramework-SystemCore
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemCore/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemCore.dll
    UIAutomationTypes
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/UIAutomationTypes/v4.0_4.0.0.0__31bf3856ad364e35/UIAutomationTypes.dll
    PnPDataObjects
    Assembly Version: 1.0.4436.40546
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/PnPDataObjects.DLL
    Accessibility
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
    Autodesk.AutoCAD.Interop
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/Autodesk.AutoCAD.Interop.DLL
    Autodesk.AutoCAD.Interop.Common
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/Autodesk.AutoCAD.Interop.Common.DLL
    PnP3dProjectPartsMgd
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/PnP3dProjectPartsMgd.DLL
    Microsoft.GeneratedCode
    Assembly Version: 1.0.0.0
    PnIDProjectPartsMgd
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/PnIDProjectPartsMgd.DLL
    PnP3dConnectionManager
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/PnP3dConnectionManager.DLL
    PnP3dPartsRepository
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/PnP3dPartsRepository.DLL
    PnP3dDataLinkManager
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/PnP3dDataLinkManager.DLL
    PnP3dOrthoProjectPart
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/PnP3dOrthoProjectPart.DLL
    System.Data
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_64/System.Data/v4.0_4.0.0.0__b77a5c561934e089/System.Data.dll
    PnPSQLiteEngine
    Assembly Version: 1.0.4436.40554
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/PnPSQLiteEngine.DLL
    System.Data.SQLite
    Assembly Version: 1.0.65.0
    Win32 Version: 1.0.65.0
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/System.Data.SQLite.DLL
    System.Transactions
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_64/System.Transactions/v4.0_4.0.0.0__b77a5c561934e089/System.Transactions.dll
    Microsoft.VisualC
    Assembly Version: 10.0.0.0
    Win32 Version: 11.00.50709.17929 built by: FX45RTMREL
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Microsoft.VisualC/v4.0_10.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualC.dll
    System.EnterpriseServices
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_64/System.EnterpriseServices/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.EnterpriseServices.dll
    System.Numerics
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Numerics/v4.0_4.0.0.0__b77a5c561934e089/System.Numerics.dll
    PnIDProjectParts
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/PnIDProjectParts.Arx
    PnIdGuiUtils
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/PnIdGuiUtils.DLL
    PnIDGUIUtilMgd
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/PnIDGUIUtilMgd.DLL
    PnP3dProjectParts
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/PnP3dProjectParts.arx
    PnP3dPipeRoutingUI
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/PnP3dPipeRoutingUI.DLL
    PnP3dPipeRoutingUI.resources
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/en-US/PnP3dPipeRoutingUI.resources.DLL
    PnP3dSpecManager
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/PnP3dSpecManager.DLL
    PnPCommonUIMgdCs
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/PnPCommonUIMgdCs.DLL
    PnP3dPlantContentUpgrade
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/PnP3dPlantContentUpgrade.DLL
    PnP3dProjectManagerUI
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/PnP3dProjectManagerUI.DLL
    PnPIsoCore
    Assembly Version: 2.0.24.0
    Win32 Version: 2.0.24.00
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/PnPIsoCore.DLL
    PnP3dProjectManagerUI.resources
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/en-US/PnP3dProjectManagerUI.resources.DLL
    PnPCommonUIMgd
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/PnPCommonUIMgd.DLL
    PresentationFramework-SystemData
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemData/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemData.dll
    PnPWelcomeManager
    CodeBase: file:///c:/program%20files/autodesk/autocad%20plant%203d%202013%20-%20english/pnpwelcomemanager.arx
    AcLivePreviewContext
    PnP3dObjects
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/PnP3dObjects.dbx
    PnP3dPipeUI
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/PnP3dPipeUI.DLL
    PnPValidation
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/PnPValidation.DLL
    PnIDDwgValidation
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/PnIDDwgValidation.DLL
    PnIDDwgValidation.resources
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/en-US/PnIDDwgValidation.resources.DLL
    PnIDWorkspace
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/PnIDWorkspace.DLL
    AcLayer
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/AcLayer.DLL
    AcLayer.resources
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/en-US/AcLayer.resources.DLL
    PresentationFramework.Luna
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework.Luna/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.Luna.dll
    AcMrUi
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/AcMrUI.DLL
    AcMrUi.resources
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/en-US/AcMrUi.resources.DLL
    AcMr
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/AcMr.DLL
    System.Runtime.Serialization
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Serialization/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.Serialization.dll
    UIAutomationProvider
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/UIAutomationProvider/v4.0_4.0.0.0__31bf3856ad364e35/UIAutomationProvider.dll
    PnPDataGrid
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/PnPDataGrid.DLL
    PnPDataGrid.resources
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/en-US/PnPDataGrid.resources.DLL
    PnP3dObjectsMgd
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/PnP3dObjectsMgd.DLL
    PnP3dACPUtils
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/PnP3dACPUtils.DLL
    AcCustomize
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/AcCustomize.DLL
    AcCustomize.resources
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/en-US/AcCustomize.resources.DLL
    System.Design
    CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Design/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Design.dll
    AcCommandToolTips
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/AcCommandToolTips.DLL
    AcCommandToolTips.resources
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/en-US/AcCommandToolTips.resources.DLL
    AcDialogToolTips
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/AcDialogToolTips.DLL
    AcDialogToolTips.resources
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/en-US/AcDialogToolTips.resources.DLL
    PnP3dEquipmentUI
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/PnP3dEquipmentUI.DLL
    PnP3dCommonUIMgd
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/PnP3dCommonUIMgd.DLL
    PnPCommonDbxMgd
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/PnPCommonDbxMgd.DLL
    PnP3dEquipmentUI.resources
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/en-US/PnP3dEquipmentUI.resources.DLL
    PnP3dUIUtilsMgd
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%20Plant%203D%202013%20-%20English/PnP3dUIUtilsMgd.DLL
    ************** JIT Debugging **************
    To enable just-in-time (JIT) debugging, the .config file for this
    application or computer (machine.config) must have the
    jitDebugging value set in the system.windows.forms section.
    The application must also be compiled with debugging
    enabled.
    For example:
    <configuration>
    <system.windows.forms jitDebugging="true" />
    </configuration>
    When JIT debugging is enabled, any unhandled exception
    will be sent to the JIT debugger registered on the computer
    rather than be handled by this dialog box.
    An education isn't how much you have committed to memory, or even how much you know. It's being able to differentiate between what you know and what you don't.
    "Do or do not... there is no try"
    Master Yoda.
    Please use plain text.
    Valued Mentor
    Rich.O.3d
    Re: Made the mistake of downgrading from windows 7 to windows 8....
    11-01-2012 04:52 PM in reply to: JohnHolder
    i was wondering if someone was going to have a crack at the win8 'downgrade' (lol)
    the word I hear is DONT BOTHER unless you have a tablet
    Its microsofts first attempt at a full blown app driven touchscreen style OS so ill probably be sticking with win7 for the next couple of windows releases
    CAD Management 101:
    You can do it your own way,
    If its done just how I say!
    [Metallica:And Justice For All:1988]
    Employee
    11-01-2012 06:13 PM in reply to: JohnHolder
    Firstly.......check if the AutoCAD versions are supported on Windows 8.
    http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=19048377&linkID=9240617
    Answer....not yet.
    If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
    Jarrod Mudford
    Plant Solutions Consultant
    Global Services
    Autodesk, Inc.
    Valued Mentor
    JohnHolder
    11-02-2012 08:54 AM in reply to: JarrodMudford
    Besides the normal slew of errors Autocad has that pop up constaintly...
    Windows 8 still sucks and and is a bad idea IMO for anyone who works with a computer to use.
    Expecially with duel monitor... that is where Windows 8 really sucks.
    Master Yoda.
    *Expert Elite*
    dgorsman
    11-05-2012 08:07 AM in reply to: JohnHolder
    And this is based on... what?  Running software which isn't compatible?
    Adopt. Adapt. Overcome. Or be overcome.
    Valued Mentor
    JohnHolder
    11-05-2012 12:55 PM in reply to: JohnHolder
    Considering it crashes on software it is compatible with. It ran fairly well.
    Yes I realize I jumped the gun a little quick. After using it for a few days on my laptop with no issues.
    Master Yoda.
