Lines between two separate plant areas in P&ID - How to automate?
See the image below (or attached) for the general gist. "Line" refers to a pipe line on a P&ID.
Hopefully a visual diagram is better than a wall of text.
I'm still fairly new at AutoCAD and this has me stumped. There doesn't seem to be a work around.
TomislavGolubovic
I'd make the Area number come from a drawing property, rather than a class.
Tomislav Golubovic
Technical Specialist - Plant and Infrastructure
Autodesk Australia / New Zealand
Autodesk, Inc.
Autodesk ANZ YouTube Channel
How would I got about doing that? Is it something involving the project properties to change the acquire mode?
cadwomen
so if your "separate plant areas" different drawings , this is the reason for your trouble i think
cw
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
TomislavGolubovic
Is each drawing a different area, or are the lines in each P&ID a different area?
For example, PID-001.dwg is Area 01, and PID-002.dwg is Area 02?
OR
Does PID-001.dwg have Area 01, 02, 03 in it, depending on the line?
Tomislav Golubovic
Autodesk, Inc.
It's option 1. ie "PID-001.dwg is Area 01, and PID-002.dwg is Area 02"
The trick is that when the area number is changed on one side, its either ouputs (in the "Plant area" field)
- "?" If the "Plant Area" field in the line properties is set to "acquire mode"
OR
- Some constant number, if the same field is set to "override mode"
I'm trying to get it so that the computer arbitrarily, chooses an automatic plant area. (So that ? or the constant number DOESN'T appear)
After much digging and uncovering, I found that I was missing some information!
This thing that I'm dealing with isn't a default arrangement for tagging P&ID lines. It turns out that the property "PlantArea" isn't a default property for AutoCad Plant 3D, it's an acquired property from "General.Drawing Area". Which explains the unique problem.
We've decided to use a Excel database update to fix any problems with Area changes, since the whole reprogramming idea is a bit daunting.
