• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Plant 3D
    Active Member
    cpambo
    Line Number format in Iso
    544 Views, 4 Replies
    09-03-2011 09:35 AM
    Hi, I'm trying to set up the format for the line number.  I've already done it in the TagFormatName but when I generate the isometric it keeps on putting extra fields.  Example: my TagFormatName is <Size>-<Service>-<Spec>-<Number> but the isometric callout has added "-<Size>-<Spec>" after my TagFormatName.  How can I take it off?
    Thanks in advance!
    cpambo
    Please use plain text.
    Valued Mentor
    Rich.O.3d
    Re: Line Number format in Iso
    09-04-2011 03:09 PM in reply to: cpambo
    you want to look at the tag annotations (to the right of where you set the tag format under the 'P3d Line Group' node...go to the 'Pipe Run Component' node)
    I think that you may be using this one...Line Number Callout [Line Number Tag]
    try this one...Full Line Number Callout [Size-Line Number Tag-Spec]
    CAD Management 101:
    You can do it your own way,
    If its done just how I say!
    [Metallica:And Justice For All:1988]
    Active Member
    cpambo
    09-05-2011 04:57 PM in reply to: Rich.O.3d
    That did it!
    Thanks for the help, richos69.
    Valued Contributor
    neonade
    08-06-2012 12:35 AM in reply to: Rich.O.3d
    Hello Richos,
    Is this applicable on isometric drawings generated.
    I think this is the tag for generated ortho drawings.
    Valued Contributor
    neonade
    08-06-2012 12:43 AM in reply to: cpambo
