• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Plant 3D
    Line Number Issue
    668 Views, 8 Replies
    08-30-2012 12:18 PM
    please see attached.
    Please use plain text.
    Product Support
    Re: Line Number Issue
    09-10-2012 02:28 PM in reply to: thebearjed
    The options in the 3D pipe line group are not the same as the P&ID group. What is showing up in the 3D pipe line group is not the same as P&ID line group. I am attaching a document that will help guide you through this, let me know if this solves your issue for you.
    If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
    Quentin Contreras
    Support Specialist
    Product Support
    danielvprz
    09-12-2012 12:54 PM in reply to: thebearjed
    Hello!
    I'm having the same problem.
    I've followed all steps from the tutorial and no matter what I do, I can't get nothing different from the image 01.
    Any ideas?
    How the "tag format" in the "p3d Line Group" should be? For now it looks like image 02
    Thanks!
    Daniel
    Distinguished Contributor
    Arun_Kumar_K
    09-12-2012 11:07 PM in reply to: danielvprz
    We are having a issue in mapping the custom spec created for Plant3d to be mapped in P&ID.
    Say for example, we created a spec Name "D5AC" in spec creator.
    How to map the above spec in P&ID.
    Arun_Kumar_K
    09-12-2012 11:23 PM in reply to: Arun_Kumar_K
    Presently the option is only to add the spec name instead of mapping in the list shown against the spec in class setting of P&ID.
    By doing the above, the software doesn't recognise and map the same in Plant3d
    danielvprz
    09-13-2012 08:06 AM in reply to: Arun_Kumar_K
    I'm trying some differents things today.
    I've changed the "Tag Format" in the P3D Line Group as seen in the image attached.
    From this, I got some very strange things, like 2 formats of "Line Number Tag".
    One only with the propriety "number", and other with the proprieties "number" and "service" (both from the PID mapping) and a "?" as response to the required fields "size" and "spec" .
    All this in the same 3d drawing!!! :-o
    How this is possible?
    Maybe I'm making things too much complicated!
    I only need the "line Number tag" like this: 2"-AI-201-A1A - (size + service + number + spec).
    It seems to me like an easy thing to do, but I'm having a hard time with it!
    Is there an easy way to do this?
    Product Support
    09-19-2012 02:40 PM in reply to: thebearjed
    From looking a the screen shots, your P&ID Line Number Tag looks like it wat setup up under P&ID Class Definitions-->Pipe Line Group. From the document I sent to you the P&ID Line Number Tag needs to be done in P&ID Class Definitions-->Engineering Items-->Lines-->Pipe Line Segments. Give that a try and let me know if that helps.
    Quentin Contreras
    Support Specialist
    Product Support
    danielvprz
    09-21-2012 07:36 AM in reply to: thebearjed
    Hello Quentin!
    Thanks for your reply!
    It looks like all the Line Number configurations here are exactly like your .doc.
    I'll post some images of my Line Number configurations of the P&ID and P3D Line Group.
    Could you please check them?
    I'm pretty sure that my mistake is on one of these itens
    danielvprz
    09-21-2012 07:39 AM in reply to: danielvprz
    Also, here is one image of my Object Mapping!
    Thanks!
