- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I'm completely stumped on this one. I'm having a terrible time trying to get a stub end & lap joint flange place in my model. I've been somewhat successful in getting a stub end/lap joint flange to connect to another stub-end/lap joing flange but the problem comes when I try to connect to an equipment nozzle or valve. From all of the other posts I see everyone says it should work out of the box but I'm having no luck. Here's where I'm at:
Created a new spec taking the only stub ends and lap joint flanges available in ASME Pipe & Fittings catalog. I can't find anything anywhere that tells me which bolts and gaskets I need to make a lap joint connection so in this spec I added every bolt and gasket available. So what I'm saying is that I've got everything in the spec.
Lap joints won't connect to other lap joints or to valves or nozzles. Here's the error I'm receiving when trying to continue routing from a ball valve::
Started hacking around with the Joint Setup dialog and was finally able to get lap joints to connect to other lap joints. Still can't connect to the valves.
Can someone please tell me exactly what my joint settings need to be? I've attached a pic of how my settings are right now.
Thanks!!
Bob
