• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Plant 3D
    Distinguished Contributor
    PatrickByrne
    Keep construction lines after using PLANTCONVERTLINETOPIPE
    224 Views, 5 Replies
    12-12-2012 07:39 PM
    When using the "line to pipe" command (PLANTCONVERTLINETOPIPE), I select the construction lines for the pipe to draw, after putting in the pipe it deletes the construction lines. Is there a setting so that these lines are not deleted.
    Please use plain text.
    Member
    richard
    Re: Keep construction lines after using PLANTCONVERTLINETOPIPE
    12-12-2012 11:51 PM in reply to: PatrickByrne
    Pick option erase after starting the Line to Pipe command, then select no.
    Richard Strikker
    CADTEAM.NL
    PatrickByrne
    12-13-2012 02:41 AM in reply to: richard
    Thank you, do you know if there is a setting for that so that the line is never erased?
    Product Support
    12-17-2012 10:17 PM in reply to: PatrickByrne
    Hi PatrickByrne,
    Currently, there is no such system variable to control the lines never be erased.
    Thanks.
    Lei Lan
    Support Specialist
    Product Support
    Autodesk, Inc.
    PatrickByrne
    12-17-2012 10:37 PM in reply to: lanl
    Any chance you could be added to the wish list.
    Valued Contributor
    01-23-2013 04:43 AM in reply to: PatrickByrne
    The way I accomplish converting line to pipe and keeping construction lines is to draw all construction lines on a dedicated layer (ex. Pipe Construction). I then freeze the "pipe construction layer before starting the line to pipe command. I then just thaw the pipe construction layer. It sounds complicated but I have toolbar button programed with a macro to do everything in one click. I will paste my macro below for reference. Just create a new custom command and program to button.
    <^C^C-layer;s;0;lo;pipe_construction;;select \plantconvertlinetopipe -layer;u;pipe_construction;s;pipe_construction;; >
    Chad
