• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Plant 3D
    followsea
    Isometrics Issues: Several components are merged into one row in BOM
    372 Views, 3 Replies
    09-24-2012 08:35 AM
    I encountered a problem when generating isometrics:
     Several components with same type and different size  are merged into one row in BOM,  and are  gived the same item number, Quatity is the sum of all.
    Above I use "Long description (Family)" for the <description> field in the table. After I Change it to "Long description (Size)" , then it becames:
    This time the PIPES are correct, but FITTINGS/FLANGES/VALVES are still not.
    I Found that this happens only when I use  specs built by myself(Such as Spec base on GB Catalogue), When I model the same pipes with Specs come with the software, it will be allright. Below is  the BOM appears modeling by Spec CS150:
    Then it's no problem.
    Any one know why? This problem is annoying me and my colleagues very  much. So many Isometric drawings must be  amended by hand!
    P3D 2012 and P3D 2013 have the same problem.
    PS: Searching the forum found that others have the same problem, but there's no resolution untill now.
    http://forums.autodesk.com/t5/AutoCAD-Plant-3D/ISO-configuration-issues/m-p/3267102/highlight/true#M...
    http://forums.autodesk.com/t5/AutoCAD-Plant-3D/BOM-Need-for-every-size-an-own-pos-no/m-p/3609146/hig...
    PCFs:
    Please use plain text.
    Valued Contributor
    neonade
    Re: Isometrics Issues: Several components are merged into one row in BOM
    09-30-2012 07:54 PM in reply to: followsea
    This seems to be strange.Seems working ok with my Plant3d 2013.
    Could you post your specs so that I can use it.
    Distinguished Contributor
    Arun_Kumar_K
    10-05-2012 08:49 AM in reply to: neonade
    You might have specified the Item code for the above items same in you custom spec, that would have caused this issue.
    Please check your spec again.
    followsea
    10-12-2012 05:24 AM in reply to: Arun_Kumar_K
    The itemcode of all the spec is blank.
