• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Plant 3D
    Valued Contributor
    neonade
    Accepted Solution
    Isometric BOM-exact length of pipe
    145 Views, 2 Replies
    11-16-2011 06:36 PM
    Guys,
    Is there a way i can change the default quantity (total length) of pipe on the BOM of the isometric, changing it from Meter to Millimeter.
    Please use plain text.
    New Member
    Re: Isometric BOM-exact length of pipe
    04-02-2013 12:37 PM in reply to: neonade
    i don't have the answer for your question but me i have one for you! How did you seperate your pipe size in the BOM
    I always have label #1 for every pipe nominal size and grouped in item #1 in BOM. I tried different description and it always group it in item #1 with 2 description side by side....
    HELP ME PLEASE!!! :smileyhappy:
    Valued Mentor
    ybogdanov
    04-02-2013 03:29 PM in reply to: alain.mallette
    Open IsoConfig.xml of your style format, and search the following lines, change scale in the las line from 0,001 to 1:
    Precision: (string); Options include Precision<N> where N is in the range of 1 to 9.
    <!-- 'Prefix': (string); The prefix that will be added to the formatted measurement. -->
    <!-- 'Suffix': (string); The suffix that will be appended to the formatted measurement. -->
    <!-- 'Scale': (double); The scale factor that will apply to the measurement. e.g. 0.001. -->
    <!-- 'Decimal': (string); The decimal separator. e.g. '.', ',' or ' '. -->
    <Style Name="Imperial" UnitFormat="Architectural" Precision="Precision5" Prefix="" Suffix="" Scale="1" Decimal="." />
    <Style Name="ImperialSize" UnitFormat="Fractional" Precision="Precision5" Prefix="" Suffix="&quot;" Scale="1" Decimal="." />
    <Style Name="ImperialPipeLength" UnitFormat="Architectural" Precision="Precision5" Prefix="" Suffix="" Scale="1" Decimal="." />
    <Style Name="ImperialPipeLengthAlt" UnitFormat="Architectural" Precision="Precision1" Prefix="" Suffix="" Scale="1" Decimal="." />
    <Style Name="Metric" UnitFormat="Decimal" Precision="Precision1" Prefix="" Suffix="" Scale="1" Decimal="." />
    <Style Name="MetricSize" UnitFormat="Decimal" Precision="Precision1" Prefix="" Suffix="" Scale="1" Decimal="." />
    <Style Name="MetricPipeLength" UnitFormat="Decimal" Precision="Precision1" Prefix="" Suffix="mm" Scale="1" Decimal="." />
    <Style Name="MetricPipeLengthAlt" UnitFormat="Decimal" Precision="Precision2" Prefix="" Suffix="M" Scale="0.001" Decimal="." />
    </Styles>
    Yury Bogdanov
    ASIDEK(Grupo CT)
    Barcelona (Spain)
