Hi All members and Autodesk.
Above is not correct solution
Where is the switch to control this?
I don't want to edit the config file this way.
I juist want to switch between,
<Style Name="MetricPipeLength" UnitFormat="Decimal" Precision="Precision1" Prefix="" Suffix="mm" Scale="1" Decimal="." />
<Style Name="MetricPipeLengthAlt" UnitFormat="Decimal" Precision="Precision2" Prefix="" Suffix="M" Scale="0.001" Decimal="." />
Some of my clients has M and MM in the same project.
And where can I change the precision of digits behind the dot?
Now there is 1 digit behind the dot and for MM units that's weird.
I cant show an size of 850.6 MM this should be 851 MM
where can I change this?
Cam someone point me to the switch responsible for the 2 lines above?
Kind regards
If this was of any help please kudo and/or Accept as Solution
Kind Regards
