• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Plant 3D
    Valued Contributor
    Isogen always generates the same line number
    200 Views, 4 Replies
    04-22-2010 05:57 AM
    I all I have some problems with Isogen in this project.
    When I try to generate one isometric and select one line number from the check list, it generate always the same line number doesn't matter what line I chose.
    Can Autodesk check what is wrong?
    Her is the link for the file:
    http://www.pipedrafting.com/40155.zip
    Please use plain text.
    Valued Contributor
    Re: Isogen always generates the same line number
    04-23-2010 02:24 AM in reply to: abilioramos
    Hello any one please!!!!
    Employee
    04-23-2010 03:56 AM in reply to: abilioramos
    Hi Abilio, I am able to extract the Iso's OK for your project. In project manager, switch to Isometric DWG tab, right clock on the line number and create iso. See if it producing the correct iso.
    Thanks, Siva (Autodesk)
    Siva Thankappan
    Technical Sales, Plant Solutions, Asia Pacific
    Autodesk Singapore
    Valued Contributor
    04-23-2010 05:01 AM in reply to: abilioramos
    Thanks Siva, the way you described it works
    But this is what I'm doing:
    1 - I go to Iso Panel "Ribbon" and click on Production ISO, in the popup dialog box I filter for the line number P30025 press next (see img01).
    2 - Them I select the Iso Type "Check" Check the overwright checkbox and click create (see img02).
    3 - Them I open the generated Iso but the line is the P33003, in the Bottom Right corner the line number is P33003 and not P30025 (see img03).
    This is for all the lines that I select If i use the filter or simply select one form the list, the isometric generated is always the P33003.
    Also if you go to the project manager, switch to Isometric DWG tab right click on the check folder, select Production Iso you will get the popup dialog box, them filter or not, and all the process that I have described repeats all again.
    Can you check what is wrong?
    Employee
    04-23-2010 05:19 AM in reply to: abilioramos
    Looks like a bug with the filter. Try without filter. I willreport to our testers.
    Siva Thankappan
    Autodesk Singapore
