• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Plant 3D
    cad.westie
    Accepted Solution
    Isogen Spec Breaks
    1348 Views, 11 Replies
    11-08-2010 06:25 PM
    Does anyone know how to suppress the isogen spec breaks ? I assume this can be done by editing the .opl file, but unsure of which switch number this is.
    Please use plain text.
    Re: Isogen Spec Breaks
    11-09-2010 10:28 AM in reply to: cad.westie
    The only switch in the .opl that has to do with spec breaks is #114 and it is only for single sided or double sided spec breaks.  I would suspect that if you have any chance it will be adjusting the alternate text file #232.  I believe that there is functionality built into isogen that says that if you blank out the value ("SPEC") for #232 that it will suppress the call out altogether.  I know that this works for other things in the atext file so hopefully it will work here.  I haven't tried it though, so let us know how it works!
    cad.westie
    11-09-2010 11:56 AM in reply to: cad.westie
    Thanks for the solution, adding 232 as blank to the alternative text file worked.
    Distinguished Contributor
    11-20-2010 03:58 PM in reply to: awerning
    Where can you find the list of "AText identification numbers" - is there a manual covering this topic some where or a file within P3D?
    Gary
    cad.westie
    11-21-2010 11:48 AM in reply to: MOLGRAND
    Hope this is what you are after.
    11-21-2010 02:45 PM in reply to: cad.westie
    Valued Mentor
    Rich.O.3d
    09-12-2012 10:14 PM in reply to: cad.westie
    So...how to turn them off in 2012???
    CAD Management 101:
    You can do it your own way,
    If its done just how I say!
    [Metallica:And Justice For All:1988]
    cad.westie
    09-13-2012 04:10 PM in reply to: Rich.O.3d
    The following worked for me : Edit the isoconfig.xml file and search for "specbreak" then rem out the line as shown below by adding !-- :
    <!--<AnnotationStyle Name="SpecBreak" TextStyle="AdskIsoAnnotation" BlockName="AnnoSpecBreaker" /> -->
    Valued Mentor
    Rich.O.3d
    09-13-2012 09:44 PM in reply to: cad.westie
    thanks
    I just renamed the SpecBreaker block in the symbols file.  did the job
    I was looking for the 'enabled' true setting to change to false but the switch doesnt seem to be coded
    CAD Management 101:
    Arun_Kumar_K
    09-13-2012 11:36 PM in reply to: Rich.O.3d
    Can anyone ellobrate "What is Isogen spec breaker", as i don't understand, ll be useful to me.
