• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Plant 3D
    Distinguished Contributor
    PatrickByrne
    Is it possible to erase the second flange but keep gasket and bolts
    224 Views, 3 Replies
    12-17-2012 12:46 PM
    At the end of a pipe i need to keep the bolts and gaskets, is it possible to erase the second flange but keep the bolts and gaskets.
    We could add in a piece of equipment and continue from that but I just want to know if it is possible.
    Please use plain text.
    hendriksegveld
    Re: Is it possible to erase the second flange but keep gasket and bolts
    12-18-2012 06:47 AM in reply to: PatrickByrne
    you can make the second flange in the properties status = existing (normally status=new)
    Arun_Kumar_K
    12-25-2012 01:59 AM in reply to: hendriksegveld
    Thanks, it solved my problem too.
    Arun_Kumar_K
    12-26-2012 06:50 AM in reply to: Arun_Kumar_K
    Similar to this, I have an issue in P&ID. How to keep the "Other vendor scope" lines and valves away from valve schedule and line list.
