• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD Plant 3D
    cad.westie
    Accepted Solution
    Insulation Problem
    723 Views, 5 Replies
    11-21-2010 07:50 PM
    Does anyone know why the insulation looks misaligned with the elbow centerlines (see attached image) ? It only seems  to do this on my elbows where the radius is smaller than the elbow length ie the elbows have a small straight at each end.
    Peter
    Please use plain text.
    Contributor Bob
    Re: Insulation Problem
    11-29-2010 10:15 AM in reply to: cad.westie
    Which snap are you using when placing the insulation symbol?
    cad.westie
    11-29-2010 11:38 AM in reply to: cad.westie
    I am not attaching insulation to the line I am selecting the line and then in properties pallette applying an insulation type & thickness to it. I believe the problem is due to the elbows having a straight stub on each end and the insulation doesnt seem to allow for this.
    Regards, Peter.
    Valued Contributor
    neonade
    07-14-2011 07:12 PM in reply to: cad.westie
    This should have the same values, are these customized elbow?
    Member
    10-11-2012 06:55 AM in reply to: neonade
    Has anybody another idea? I have the same problem, and radius in spec editor isn't a solution of the problem.
    Member
    10-11-2012 11:53 PM in reply to: cad.westie
    Sorry for a mess. After some more tries the solution is working. I forgot to account fasteners in radius value.
