AutoCAD Plant 3D
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Instrument ation for Plant 2011
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi all,
I've been playing around with the different specs, specifically how to add an instrument class to show PI, TI etc.
Perhaps I'm missing something as I can't figure out how to create one which is recognized by isogen, or even see a 3D class for instruments other than the inline variety.
What I've done is modeled the instrument as a piece of equipment, ok this works for now, but the iso produced will show being connected to a piece of equipment with nozzle number, not exactly ideal.
I'm coming from an AutoPLANT background which supported instruments nicely.
Is there an easier way to do this? Any tutorials floating around?
Re: Instrument ation for Plant 2011
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
chbiz,
The only way you can have instruments is to add them to spec as new component, create a block to represent a gage and then in the catalog editor create new component > use custom geometry.
Select a category, probably valve and then assign the block to the component, in the component properties define the skey=IDFL, type=INSTRUMENT-DIAL this way they apprear nicley on the isometric drawings. I have done this and it works.
Regards
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Great, Thanks for the info, will save me a huge headache.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I followed your procedure and it works fine, but when making the isometric for some reason, that I couldn't find out yet, the instrument splits the line in different files. Its a flanged flow meter, 2 ports. All components, including the flow meter, have the same line tag number.. Any ideas ?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
An instrument is NOT a valve.
If you make it like that, then the instruments show in the data manager as a valve...not so good for making valve schedules.
Has anyone worked out how to make an instrument in a cat that shows as instrument not a valve
You can do it your own way,
If its done just how I say!
[Metallica:And Justice For All:1988]
