• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD Plant 3D
    Distinguished Contributor
    philip
    ISSUE WITH 45 TEE's
    308 Views, 9 Replies
    06-18-2012 02:11 PM
    Started a project in 2012 and had things working okay had run some isos off and all was good (image "45-2012")
    Then migrated to 2013 and added a whole lot of new pipes reran some iso which have changed and now am finding that 45 tee's are not working anymore(image "45-2013")
    Have started a new project and created a "custom part" and found that the issue is there still (thought it might be some of our custom Isometric symbols).
    is this a bug with 2013??
    Please use plain text.
    Product Support
    Venkatesan.A
    Re: ISSUE WITH 45 TEE's
    06-19-2012 12:06 AM in reply to: philip
    Philip,
    Thanks for highlighting.
    A change request has been opened relating to this issue.
    Venkatesan.A
    Support Specialist
    Product Support
    Autodesk, Inc.
    philip
    06-19-2012 01:09 PM in reply to: Venkatesan.A
    any idea if this may come out as a fix this year or will it be in the next release of Plant (2014)?
    Just so i know either to use or not to use 45 tees in upcoming projects.
    Product Support
    Venkatesan.A
    06-25-2012 06:56 PM in reply to: philip
    Sorry for the late reply, I am in discussion about this issue, please give me some time.
    I will update you asap.
    Venkatesan.A
    Support Specialist
    Product Support
    Autodesk, Inc.
    philip
    06-25-2012 07:46 PM in reply to: Venkatesan.A
    thanks.
    pata825
    06-28-2012 01:46 PM in reply to: philip
    Have we heard anything on this yet? I am having similar issues with lateral. Anyone found a good workaround? was thinking about grabbing the block from 2012.
    philip
    06-28-2012 01:48 PM in reply to: pata825
    nothing as yet, I ended up doing a lot of manual works to get it looking half right so we could get job out.
    pata825
    06-28-2012 02:15 PM in reply to: philip
    Manual work to your isos, or were you able to figure out a workaround to get the isos to come out right?
    philip
    06-28-2012 02:19 PM in reply to: pata825
    I changed the isos after they were made by Plant.
    Only workaround i can think of is to create a user SKEY, i have not tried this yet.
    Product Support
    Venkatesan.A
    09-04-2012 08:04 PM in reply to: pata825
    A Hotfix has been issued that address this issue. The link is as below.
    http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=20164796&linkID=14116968
    Let me know if this works fine for you.
    ______________________________________________________________
    If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
    Venkatesan.A
    Support Specialist
    Product Support
    Autodesk, Inc.
