• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • AutoCAD Plant 3D
    Active Contributor
    Accepted Solution
    ISO splitting
    967 Views, 15 Replies
    10-01-2012 11:38 PM
    Hi All
    I would like to know if anyone has any more information on ISO splitting. I have a pipe and 2 smaller pipes are connected using half couplings (as seen in attached screen shot). When I generate an ISO it created 4 different ISO's instead of 1, even when I select the "Force Iso onto one sheet" option in the Advanced Iso Creation options. I did some re search and I found these 2 blogs (http://www.davetyner.com/forum/showthread.php?10029-Plant-3D-2012-Isometric-Splitting&highlight=forc... , http://forums.autodesk.com/t5/AutoCAD-Plant-3D/Force-iso-onto-one-sheet/td-p/3275015) on this and have tried both, tested connections, i have made sure all the line numbers are correct etc and still I get the same result (4 ISO's). I hope Autodesk or anyone can give me some insight into this, or tell me if this is a bug.
    Tarryn
    Please use plain text.
    Valued Mentor
    Rich.O.3d
    Re: ISO splitting
    10-01-2012 11:41 PM in reply to: tarrynd
    right click a component
    add to selection all connected components
    do all your parts highlight?
    if not, then your iso will not be connected
    CAD Management 101:
    You can do it your own way,
    If its done just how I say!
    [Metallica:And Justice For All:1988]
    Active Contributor
    Re: ISO splitting
    10-01-2012 11:48 PM in reply to: Rich.O.3d
    Hi There
    Thanks for the reply.
    This is one of the 1st things I checked, everything is connected. The ISO generates perfectly when I change the half coupling to stub in's. The end types for my Half coupling are 1=THDF; 2=BV, not sure if this has anything to do with it.
    Tarryn
    New Member
    Re: ISO splitting
    10-02-2012 01:53 AM in reply to: tarrynd
    Hi Tarryn, is it possible that you have toggled the iso property changes, under the Iso Creation Options? Here you can force a iso split according material, spec or line No changes. Also the DWG congestion slider where is that set to? Just a couple of suggestions, i hope they help.
    Active Contributor
    Re: ISO splitting
    10-02-2012 02:01 AM in reply to: carnie
    Hi
    Thank you for the reply and suggestions. The "Spilt Iso when property changes" option has never been ticked, I normally check the "Force Iso onto one sheet" option however. Also I have tested both sliding the "drawing congestion splitting" option to the highest as well as the lowest and tried producing ISO's both ways, neither make a difference. I mentioned that if I change the half coupling to a stub in, then the Iso is produced correctly, the minute it is half couplings (which is what I need) it splits into 4 Iso's at the couplings. I have checked all is connected and they are... I am not sure what else I could possibly try...
    Valued Mentor
    Rich.O.3d
    Re: ISO splitting
    10-02-2012 03:31 PM in reply to: tarrynd
    did you make the half couple or get it from an existing catalogue
    I remember having an issue with them when i made them...i think i ended up copying an olet and making my own
    CAD Management 101:
    Active Contributor
    Re: ISO splitting
    10-02-2012 10:17 PM in reply to: Rich.O.3d
    The Half coupling was actually brought through from the AutoPlant Specs.
    Thank you. I am have also contacted ask the expert, Jarrod Mudford, and he has provided me with the same solution, I will test this out on my side today and report back on my results.
    Valued Mentor
    Rich.O.3d
    Re: ISO splitting
    10-02-2012 11:08 PM in reply to: tarrynd
    ahhh..Muddies on the case......he will get you sorted
    CAD Management 101:
    New Member
    Re: ISO splitting
    01-01-2013 06:40 PM in reply to: tarrynd
    Hi tarrynd,
    I have exactly same problem splitted drawings with half couplings.
    Could you pls report back your solution?
    Is it solved by making up an olet?
    many thanks!
    Active Contributor
    Re: ISO splitting
    01-13-2013 10:56 PM in reply to: tarrynd
    Hi There
    Yes creating my Half couplings as OLETS sorted out my problems. It was a bit of a long way around because instead of creating a half coupling in my spec with only the size on my half coupling i had to create mutiple olets because with olets you need to specify both of the connecting components sizes. So for my 25mm Half coupling, I had to create 25x50, 25x65, 25x80, 25x100, etc etc olets. But in the end they work well and my ISO's are pulled correctly.
    hope this helps.
    Kind regards,
    Tarryn
