• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Plant 3D
    Active Contributor
    Jorgen1990
    ISO creation error
    380 Views, 6 Replies
    01-27-2012 08:37 AM
    Hello!
    I tried to create an isometric from a pipeline and got an error message "errors were encountered". Error log and picture of the pipeline are attached. What could I have done wrong? I have managed to successfully create isos from other pipelines in the same project.There are no disconnections in the pipeline, everything should be OK.
    The pipeline is the yellow one in the picture.
    Jörgen
    Please use plain text.
    Employee
    Adsk_amitb
    Re: ISO creation error
    01-29-2012 08:58 PM in reply to: Jorgen1990
    Can you provide the PCF please?
    Active Contributor
    Jorgen1990
    02-01-2012 12:17 AM in reply to: Adsk_amitb
    Yes, here it is. Program didn't name it by the line number, but named it UserDefinedLine.pcf for some reason.
    Here is the download link for PCF file: http://www.speedyshare.com/file/cgaW2/UserDefinedLine.pcf
    Jörgen
    Employee
    karthik.nathan
    02-07-2012 08:17 PM in reply to: Jorgen1990
    Hi Jörgen,
    I was able to generate isos successfully for Check, Final and Stress. Any chance you can attach the IsoConfig.xml and the Iso.dwt for which the iso creation for this pcf is failing.
    Karthik
    New Member
    09-11-2012 12:12 PM in reply to: Jorgen1990
    I think Jorgen and I are in the same boat.
    I ran t he ISO creation before and it worked, but now I get the " Errors were encountered" message.
    Can you help me out with this problem please? I appreciate your assistance.
    Patrick
    Distinguished Contributor
    Arun_Kumar_K
    09-14-2012 08:44 AM in reply to: Jorgen1990
    please do the following, its only a temporary work flow. Copy isoconfig file from other isostyle folder and paste in your required isostyle folder.
    Arun_Kumar_K
    09-14-2012 08:48 AM in reply to: Arun_Kumar_K
    Make sure you keep a backup of your present isoconfig file.
