• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Plant 3D
    Valued Contributor
    Arch_art
    Accepted Solution
    ISO - Symbol not display correctly
    261 Views, 3 Replies
    08-16-2012 07:09 PM
    I am trying to create a iso, in the pipework, I have placed a Nipple. Nipple is defined as
    TYPE=COUPLING, SKEY=NRSC; Which make it on the iso drawing. But problem is, instead of showing the block "nipple" accordingly the IsoSkeyAcadBlockMap, it shows a block call "placeholder". Now, I don't know why it is doing this. The only thing that I can think of is the Type is not quite right. So I tried Fittings, Nipple. It doesn't even work. Is anyone knows this?
    Also, where I can find the TYPE definition? Is there a list which tell you what fittings should be considered as what TYPE in Plant 3D?
    Please use plain text.
    Valued Contributor
    Arch_art
    Re: ISO - Symbol not display correctly
    08-16-2012 09:37 PM in reply to: Arch_art
    It display properly now. I don't know why. It seems like Plant 3D need to think a little while. Or I need to restart Plant 3D. I am not sure. Any one can confirm this?
    I sitll like to have the TYPE list if any one knows this.
    *Expert Elite*
    dave.wolfe
    08-17-2012 06:21 AM in reply to: Arch_art
    I've found it frequently doesn't like the space after the comma between the type and the skey so:
    TYPE=XXX, SKEY=XXXX is bad
    TYPE=XXX,SKEY=XXXX is good.
    Dave Wolfe
    Isaiah 57:15
    ECAD, Inc.
    Tips and Tricks on our blog: Process Design, from the Outside
    A P3D Authorized Reseller
    Valued Contributor
    Arch_art
    08-19-2012 03:10 PM in reply to: dave.wolfe
    Thanks, Dave
    This does fix the problem I have. Interesting !
