• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Plant 3D
    Distinguished Contributor
    ISO PROBLEMS - SPLIT POINT & DIM to POINT
    325 Views, 4 Replies
    09-01-2012 01:18 PM
    I'm having a little trouble in tweaking my Isos - when using the lap joint & spin flange they tend to break for continuation at the lap joint b/w & not on the gasket face. Also they seam to want to dimension to the lap joint b/w & not to the gasket face see attached PDF example.
    Any helpers?
    Regards
    Gary
    Please use plain text.
    Product Support
    Re: ISO PROBLEMS - SPLIT POINT & DIM to POINT
    10-04-2012 09:53 AM in reply to: molgrand
    Do you have a small example project that you can provide for testing here?
    Dan
    Dan Scales
    Product Support Specialist
    Autodesk, Inc.
    Fwd: ISO PROBLEMS - SPLIT POINT - 1 of 2
    10-04-2012 10:56 AM in reply to: DanScales
    Hi, See attached. I have attached one of the models from a large project, along with PDF files of the Isos I ran off & a PDF of the g/a which was print from the Otho drg produced. I hope you can help as it makes the ISO drgs difficult to work with - at the moment I have 3000 Isos! Regards Gary Randall
    Product Support
    10-05-2012 06:21 AM in reply to: molgrand
    The drawing doesn't seem to have been uploaded.
    Could you try again?
    Dan
    Dan Scales
    Autodesk, Inc.
    10-05-2012 07:25 AM in reply to: DanScales
    Hi, Drg attached again Cheers
