• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Plant 3D
    Valued Contributor
    Accepted Solution
    I can not assign Tag in any Pipe Line
    483 Views, 4 Replies
    10-26-2011 11:32 PM
    Hi to everyone...
    Well I have a big problem assign tag to a Pipe line when I try to do this appear a error: (ACADP3D 2012)
                                                     "NO TAG FORMAT AVAILABLE FOR THIS COMPONENT"
        (I show you in .img added)
    1.-I routed a new line with unasigned Pipe number, when select Pipe Line I go to properties and I asign a "Pipe Line Number" (005), well after do this, in properties with pipe line selected, I go to the Properties again at "Tag" above "Pipe Line Number" and try to asign one, and the error wrote above appear.
    2.- I try to assign tag in Data Manager / Piping and Equipment / Piping Run Component / Pipe, Double click on Tag Column and the error wrote above appear again.
    3.- I deleted all, and I start Routed Pipe from P&ID Line List, I select the line to route and click in Place Item and I start to route pipe, and keep the Line Number but can not apply a Tag.
    What I do wrong? or,  What Can I Do?
    Thanks.
    Please use plain text.
    Valued Contributor
    milic.srdjan
    Re: I can not assign Tag in any Pipe Line
    10-27-2011 05:50 AM in reply to: batone79
    Halo...  :smileyhappy:
    I think that is not possible to assign TAG ONLY to a pipe, let say only piece of pipe... :smileysurprised:.
    You must assign LINE TAG NUMBER to process line...
    Because the pipe line, with a components (as valve, flange, etc...) have the same TAG number....
    If You wish to make tag, only for a pipe, NOT PIPE LINE, that is another story....
    I hope that I help a little bit :smileyvery-happy:
    Srdjan
    Employee
    BuddyLegnon
    10-27-2011 06:45 AM in reply to: batone79
    The best practice for assigning line numbers is to set your line number before you begin to model it. modeling unassigned line numbers and then going back to line number tag them is more tideous.
    If you have already modeled your lines, turn off all layers but your line number, selelct all componenets and properties those items to get a chance to assign line number tag.
    it has been my experience that modeling one line at a time, with the line number preset always delivered best results.
    after modeling one line - drop an isometric on that line to ensure its it good working order.
    Buddy Legnon
    If my post answers your question, please click the "Accept as Solution" button (you must be logged in). This helps everyone find answers more quickly.
    Valued Contributor
    10-27-2011 07:56 AM in reply to: milic.srdjan
    Hi, thanks for your Quick Replay...
    I See and after read to milic.srdian I understand that in 3D Model Routing Pipe each LIne Pipe has got a Line Number Tag or Line Number Process but not Tag as draw before in the P&id.
    I don´t know I need to try it but,  my Question is,
    can you have two same line process numbers in the same project?, AP3D allows it to?
    Thanks.
    Valued Contributor
    milic.srdjan
    10-28-2011 07:46 AM in reply to: batone79
    Yes, I think that You can have the same line number, but that It is the same pipe line...
    Or If You have some TAG standard, then You can have same line number, but different TAG NUMBER
    Like...
    2"-P-150-0233-AX23-H (process)
    10"-W-150-0233-AX23-P (water)
    Srdjan
