• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Plant 3D
    Active Contributor
    vannmannen
    How to use LAPPED FLANGE?
    342 Views, 5 Replies
    01-11-2013 12:16 AM
    I do not get to the bottom of this and I have tried all sorts things in Plant 3D.
    My spec has got LAPPED FLANGE (RF/LF), STUB END (RF/BE) and all valves are RF/RF.
    The STUB END in Plant 3D has got a LAP connection by default. In the model this STUB does not even show a connection point on the flange side. It appears as a connector. How can I make this work?
    Pic 1 shows no snap-point at flange side
    Pic 2 shoes snap-point on the welded side of flange
    Please use plain text.
    Employee
    TomislavGolubovic
    Re: How to use LAPPED FLANGE?
    01-13-2013 02:56 PM in reply to: vannmannen
    Are you trying to connect to an END osnap? Try the NODE osnap.
    Tomislav Golubovic
    Plant Solutions Engineer
    Autodesk Australia / New Zealand
    Active Contributor
    vannmannen
    01-15-2013 07:32 PM in reply to: TomislavGolubovic
    Thanks for your suggestion.
    The components connect when I use the NODE snap ut I get error message and there is a leakage. See attachment.
    Employee
    TomislavGolubovic
    01-15-2013 09:35 PM in reply to: vannmannen
    The error message is telling you to check the 3 properties. Check one against the other and see what the difference is. When you find the conflicting properties, you'll have to take steps to rectify it, either by editing the properties again or the connection rules.
    Tomislav Golubovic
    Product Support
    gersteb
    01-18-2013 01:21 AM in reply to: vannmannen
    Hi Trygve,
    I have looked for the properties of the flange and valve which have attached here. So for a valid connection it is defined in your project that the NominalDiameter, the PressureClass and the Facing of the connected ports are the same.
    For your flange I can see that the properties are
    for the port S1:
    NominalDiameter = 8
    PressureClass = 150
    Facing = FF
    for the port S2:
    NominalDiameter = 8
    PressureClass = 150
    Facing = no value
    For your valve the values are
    for the port S1:
    NominalDiameter = 8
    PressureClass = 150
    Facing = RF
    NominalDiameter = 8
    PressureClass = 150
    Facing = RF
    So the facing for the valves and the flange are different. You have to redefine your properties here, so a match is possible.
    Please, inform us if we could help you.
    Regards
    Bernd
    Bernd Gerstenberger
    Senior Support Specialist
    Product Support
    Active Contributor
    vannmannen
    01-18-2013 01:45 AM in reply to: gersteb
    I have found a solution to this problem.
    The thing is that the lapped flange is RF in my piping spec while the default Plant 3D catalog only offer FF facing for lapped flange. Did a duplication of the FF lapped flange and changed facing to RF.
    Voilà !!!!
