• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Plant 3D
    berucheva
    How to spot a user who has opened a project
    178 Views, 4 Replies
    07-05-2012 08:29 AM
    i've been experiencing a problem with project setup. The problem is i can't run Project Setup if another user has opened the project.
    Let's get into more detail.
    if a user has opened a drawing, i can see him in Project Manager. Thus i can spot him and tell him to close the project in order to set it up. So far, so good.
    Now imagine that a user has opened a project but hasn't opened a single project drawing. I can't see him in Project Manager. Nevertheless he blocks the project from being re-setup via Project Setup. I mean I can neither run Project Setup, no find out who has opened and blocked the project.
    I'd like to know if there's a way to spot a user who has opened (and thus blocked) a project without opening a project drawing.
    Thank you!
    Please use plain text.
    Distinguished Contributor
    PatrickByrne
    Re: How to spot a user who has opened a project
    07-09-2012 05:05 AM in reply to: berucheva
    This might help in the future. If you make the file projSymbolStyle.dwg read only then the next time they go to alter the project properties it will greyed out.
    berucheva
    08-16-2012 05:08 AM in reply to: PatrickByrne
    I solved this problem. By edit C:\Program Files\Autodesk\AutoCAD Plant 3D 2013 - Russian\ru-RU\DisplayNames.xml
    *Expert Elite*
    dave.wolfe
    08-16-2012 12:25 PM in reply to: berucheva
    Can you clarify how you modified this to solve your problem?
    Dave Wolfe
    Isaiah 57:15
    ECAD, Inc.
    Tips and Tricks on our blog: Process Design, from the Outside
    A P3D Authorized Reseller
    berucheva
    08-16-2012 10:43 PM in reply to: berucheva
