• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Plant 3D
    How to handle Xref in Piping models
    255 Views, 2 Replies
    02-24-2012 04:58 AM
    Dear Users,
    I work now with Autoplant from Bentley. In Autoplant I use RWA work area to load, attach and unload xref drawings to my project. When I make a new piping file e.g. Plant Air.dwg I want to have some of my equipment xreffed and some structural parts and even other piping files to detect clashes. How do I proper attach these drawings to my piping file? Is it done using plain Xref? Then I get circular references.
    Please share your workflow.
    Stephan
    Please use plain text.
    Rave.Tam
    Re: How to handle Xref in Piping models
    02-24-2012 07:26 AM in reply to: hardsniffer
    Master drawing by area, which xref piping, equipment and structure. Piping will then xref the master drawing. Yes, you'll get circular reference but it will resolved automatically.
    If my post answers your question, please click the "Accept as Solution" button.
    Check out my blog http://lazcad.com
    dgorsman
    02-24-2012 11:27 AM in reply to: Rave.Tam
    Circular XREFs should be easily broken, by OVERLAYing models for reference purposes and only ATTACHing models which are in any given sub-area.  It can take a bit of up-front planning but the organization makes coordination much easier, especially on projects with large numbers of models.
    Adopt. Adapt. Overcome. Or be overcome.
