• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Plant 3D
    Sam2M
    How to export Structure to Revit or Detail Structure ?
    979 Views, 6 Replies
    03-06-2011 05:54 AM
    Hi
    Plant 3D export structure under SDNF format.
    But it seems than Revit Stucture and Structural Detailling are not able to read this format.
    any solution ?
    Please use plain text.
    Employee
    StructSub
    Re: How to export Structure to Revit or Detail Structure ?
    03-07-2011 02:26 PM in reply to: Sam2M
    AutoCAD Plant 3D 2011 allows you to save files in SDNF format. The software assigns to its files the extension "*. SDNF". Autodesk Robot Structural Analysis allows to open such files, but when they have the extension "*. s" or "*. sdf". So just rename the file created by AutoCAD Plant 3D to give him an extension "*. s" or "*. sdf". This will allow Autodesk Robot Structural Analysis to read this file without problem.
    Regards.
    Emmanuel.
    Sam2M
    03-08-2011 12:28 AM in reply to: StructSub
    Hi
    Thanks but my question was about exportations from plant 3D to
    AutoCAD Structural Detailing
    and
    Autodesk Revit Structure
    HermannSemlitsch5177
    11-02-2011 03:47 PM in reply to: Sam2M
    i have the same problem. i created a steel structure in plant 3d but i will the edit / compled it in Structural Detailing...
    have anyone a solution with Plant3D 2012?
    Valued Mentor
    Rich.O.3d
    11-02-2011 07:47 PM in reply to: HermannSemlitsch5177
    If you get the 'extensions' for Revit Structure pack from the subscription advantage pages then you will be able to import/export sdnf files (sdnf out from plant3d - then sdnf import in revit - then ASD link from revit to steel detailing)
    CAD Management 101:
    You can do it your own way,
    If its done just how I say!
    [Metallica:And Justice For All:1988]
    11-03-2011 10:51 PM in reply to: Sam2M
    thanks for the answer but when i import it in revit, the model have no the correct length...
    i have attachted a pdf for example
    Valued Mentor
    ybogdanov
    11-04-2011 04:50 PM in reply to: HermannSemlitsch5177
    It's occured because in Plant3D you need to work in line view of structure (no "shape"). Because when you create the new memeber and in the shape visualization lengthen this memeber, the "control" line is not lengthen. That's why in shape view the structure has good visualization and in line not... And when you export to revit the plug-in use the "control"line of memeber (not virtual which is lenthen)
     You can modificated your structure in the plant3D, changed the visualization mode (the first in the list)
    Yury Bogdanov
    ASIDEK(Grupo CT)
    Barcelona (Spain)
