AutoCAD Plant 3D
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
How to edit " Structural Catalog " file with Plant 3D 2012 Spec Editor?
- Highlight
- Email to a Friend
- Report Inappropriate Content
I would like to know how to modify the Structural Catalog file since the Spec Editor can't open it. The actual catalog is missing a lot of structural profiles. I would need someone from Autodesk to tell me exactly how I can do so. If we can't do it with the Pant 3D spec editor, which software should I use?
Re: How to edit " Structural Catalog " file with Plant 3D 2012 Spec Ed
- Highlight
- Email to a Friend
The structural catalog is located in the CPAC common subfolder in the C:\AutoCAD Plant 3D 2012 Content directory.
When opening this catalog, you just need to set the extension to .acat in stead of .pcat.
In version 2011 you can only open .acat files when you use the open catalog command from the file menu.
Consultant Plant Design Software
Greenock CAD Service
- Highlight
- Email to a Friend
Have you tried this on your side? Me, I already did and it's not working in Plant 3D. I renamed the extension (made a copy first) and Spec Editor is doing nothing with it. Everything within Spec Editor stays blank. Please try on your computer and let me know.
- Highlight
- Email to a Friend
oops, indeed, the structural catalog doesn't open. I was assuming it was the same as the Nozzle catalog, which works fine.
it seems that this is 'as designed'
sorry about my initial mistake
- Highlight
- Email to a Friend
Thanks for trying to help me on this.
Now, I'm asking this to Autodesk support team:
How can we manage to modify this "Structural Catalog"? What mean or what software can we use to "hard modify" it if we can't within Plant 3D? This is a basic thing that we should do IF we want to use Plant 3D to to plant design...
- Highlight
- Email to a Friend
It appears that depth and width variables are backwards for WT shapes. A WT4x12 should measure 4" deep and 6 1/2" wide. The model comes in 6 1/2" deep and 4" wide. We found this in 2011 and it appears that it has not been corrected in 2012. This could cause interference problems with designs during constructionn
