• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Plant 3D
    Valued Contributor
    How to Create Parametric Graphics?
    367 Views, 4 Replies
    10-13-2011 08:55 AM
    Hi to everyone,
    Anybody knows if is possible to create a Custom Plant 3D Parametrics Graphic to use in Catalog Editor / Create New Component?
    If is possible, can you say How?
    Thanks.
    Please use plain text.
    Employee
    TomislavGolubovic
    Re: How to Create Parametric Graphics?
    10-16-2011 01:18 PM in reply to: batone79
    The Catalog Builder (in beta stage) might be of help:
    http://autocad.autodesk.com/?nd=plantcatalogbuilder
    Tomislav Golubovic
    Plant Solutions Engineer
    Autodesk Australia / New Zealand
    Autodesk, Inc.
    Valued Contributor
    10-18-2011 09:29 AM in reply to: TomislavGolubovic
    thanks I will test it..!!
    09-24-2012 08:12 AM in reply to: batone79
    Did you get it to work?
    I was wondering the same....
    In 2013 this should be part of the software.
    Valued Mentor
    JohnHolder
    09-24-2012 12:52 PM in reply to: snijdam
    I would suggest, taking an exisiting catalog - SAVE IT under a different name, then delete all parts.
    create a part ( I created pipe, 45 elbows and 90 elbows to start )
    export it to excel <file> <export to catalog builder>
    edit the parameters <in excel> ( you have to unprotect the worksheet usually )
    run the catalog builder
    build the catalog
    and test it... and repeat editing the parameters untill you understand how they work ( for the most part )
    This is basically what I did untill I got a rough understanding on how to build parametric parts.
    it seems to work fairly well for imperial parts, it totally bugged out trying to make metric parts.
    An education isn't how much you have committed to memory, or even how much you know. It's being able to differentiate between what you know and what you don't.
    "Do or do not... there is no try"
    Master Yoda.
