Message 1 of 9
Can anybody tell me how can I shown an ISO without the line number (line tag) shown beside the line?
I want to get rid of the line number in the right yellow circle.
And I also want to enlarge the valve text in the left yellow circle......
Can anyone give me some suggestion???![]()
In the project folder look for IsoConfig.xml,
search lhis line:
<LineNumberScheme Name="LineNumber" AnnotationStyle="Standard" Format="{0}-{1}" Alignment="SkewAligned" Enabled="false" LeaderStyle="AsNeeded" ComponentFields="Size PIPING-SPEC" LineFields="PIPELINE-REFERENCE" ComponentFormat="{0}-{1}" LineFormat="{0}" />
Add the part in red in the line.
We like to have a very simple version of iso drawings, which we plan to not show any of bolts and gaskets tagged and in the BOM, can this be possible?
Just a thought - I haven't tried this. Perhaps you can set the gaskets and bolts to "existing" status. Or you might be able to use the shop/field status.
I had worked this out myself.
you have make some changes in isoconfig.xml.
in the file, under the section of <AggregatedLists>
there are three set of
<!-- <Group Name="FASTENERS">
<RowFilter Filter="Fastener" />
<Labels>
<Label Name="fasteners" />
</Labels>
<Columns>
<Column Name="Category" />
<Column Name="Code" />
<Column Name="Size" />
</Columns>
<Sort SortBy="Type ASC,Size ASC" /> -->
This would take them out of BOM list;
and then you need to go to the section of <Theme Name="Default">
under there you will find something like this, take the red text out of the script,
<GroupScheme Name="FlangeGroup" AnnotationStyle="SRectangle" Enabled="false" Tag="XX" Alignment="FlatHorizontal" LeaderStyle="AsNeeded" Components="Flange Bolt Gasket" Field="PartNumber" IncludeMate="true" MateComponent="Flange" MateTag="XX" MateAnnoStyle="Rectangle" MultipleBlocks="false"> <Formats>
<Format Component="Flange" Format="{0}" />
<Format Component="Bolt" Format="{0}" />
<Format Component="Gasket" Format="{0}" />
</Formats>
<GroupFormats>
<GroupFormat Count="1" Format="{0}" />
<GroupFormat Count="2" Format="{0} {1}" />
<GroupFormat Count="3" Format="{0} {1} {2}" />
<GroupFormat Count="4" Format="{0} {1} {2} {3}" />
</GroupFormats> </GroupScheme> <GroupScheme Name="FlangeGroupMulti" Enabled="true" Alignment="FlatHorizontal" LeaderStyle="AsNeeded" Components="Flange Bolt Gasket" Field="PartNumber" IncludeMate="true" MateComponent="Flange" MateTag="X00" MateAnnoStyle="OneCircle" MultipleBlocks="true"> <Formats> <Format Component="Flange" Format="{0}" /> <Format Component="Bolt" Format="{0}" /> <Format Component="Gasket" Format="{0}" /> </Formats> <GroupFormats> <GroupFormat Count="1" Format="{0}" AnnotationStyle="OneCircle" Tags="X00" />
<GroupFormat Count="2" Format="{0}" AnnotationStyle="TwoCircle" Tags="X00 X03" />
<GroupFormat Count="3" Format="{0}" AnnotationStyle="ThreeCircle" Tags="X00 X03 X06" /> <GroupFormat Count="4" Format="{0}" AnnotationStyle="FourCircle" Tags="X00 X03 X06 X09" /> </GroupFormats> </GroupScheme>
I believed there are three set as well.
Once you done all that, the bolt and gasket won't show in the drawing and BOM, it will not given a number as well.
One thing that I yet to work out is, how can I make this text (see attachment) closer to each other, any thought? It would be waste of time to change every connection notes manually, drawing by drawing.
