AutoCAD Plant 3D
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
How can I add a support to a valve?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hello
How can I add a support to a valve, so that I can see the support in an isometric?
G
Re: How can I add a support to a valve?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Is the support part of the valve or another itemised part?
If its a separate part, you can place a pipe support on a valve, as you would normally on a pipe.
Tomislav Golubovic
Plant Solutions Engineer
Autodesk Australia / New Zealand
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hello
I've tried some options:
1. I create an own support in a catalog and include it into the spec and place it to the valve: I get an open end (waterdrop) and two isometrics, one with the support only
2. I include an existing support (Alignment guide) into the spec and place it to the valve: same behavior like 1.
3. I use '_PlantPipeSupportAdd' in the model and place also the 'Alignment guide': everything works fine
What shall I do? I need own supports.
best regards
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi Guido,
You have to do this on a different way because supports are special and have his own spec. Try this:
- Open in the spec editor the 'Supports catalog metric.acat' or the 'Supports catalog.acat' (depends what for units you want) from the <ContentFolder>\CPakCommon.
- Add here your new component. For the field 'Iso Symbol Type' type the value 'SUPPORT'. For the SKEY enter for example ANCH but this depends for the symbol that you want here. Look here in the IsoSkeyAcadBlockMap.xml which block is associated with the SKEY and look in the IsoSymbolStyles.dwg how the blocks are looking.
- Now you have to add this new component to the PipeSupportsSpec-spec in the same folder. This spec will be copied into the subfolder 'spec sheets' if you create a new project. If you want to add this new component to an already existing project, just open this spec from the project and add the component here.
- Now use the dynamic tool palettes for supports to add this support to a valve. If the size is known there is no more waterdrops here and you can create an isometric drawing. Because it is a dynamic tool palette, latest after closing and opening the project, the new component can be seen and used here. See attached snapshots for the results.
Please, inform me, if I could help you here.
Regards
Bernd
Bernd Gerstenberger
Senior Support Specialist
Product Support
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi Bernd,
that's the solution! Thanks.
(I've tried it with an own catalog also and it works too)
Guido
