• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Plant 3D
    Member
    Re: Help needed - Spec and catalog editor - Half coupling branch
    09-17-2012 07:16 PM in reply to: Arun_Kumar_K
    Thanks THERMAXCHENNAI
    A half coupling branching off a main header may not be best practice, but i am just the drafter trying to fill out the spec given to me by the process engineer.
    It is a cheaper solution that is quite common in lower pressure and less critical processes, and as you suggested, if it is used commonly in certain intustries then the AUTOCAD PLANT3d team should make this branch possible in the branch table.
    AUTODESK, and chance of some feedback on this?
    I have the following scenario...
    1/2" - 2" half coupling Branch
    to Branch off a 2.5" to 24" header.
    I can manually insert the half coupling that I created and connect it to the header, this work fine. I can also route from the half coupling perfectly which suggest I have made the coupling correctly.
    BUT in the branch table the coupling connection won't stay or work at all (it goes RED or goes blank) so the auto branch or continuation function just leaves a blank pipe from the centre of my header, no coupling inserted.
    Please at least let us know if it is impossibe, so i can stop trying to get it working.
    Cheers
    Please use plain text.
    Member
    09-17-2012 07:31 PM in reply to: MOLGRAND
    Thanks GARY
    You are a star for this.
    I will try it.
    It sucks that it takes such effort to do this work around for something so fundamentally simple.
    It also sucks that there is no feedback from Autodesk on this.
    Thanks for letting others know of an alternative solution.
    Cheers
    Employee
    10-09-2012 02:06 PM in reply to: lukecoxon3d
    I just recently helped someone out with this on the Ask the Expert page. It is only now that I have seen it.
    Create a new component in your catalog as an Olet. But give it the descriptions for Half Coupling and same with the dimensions. It looks like a Half Coupling but ISO's like an Olet.
    If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
    Jarrod Mudford
    Plant Solutions Consultant
    Global Services
    Distinguished Contributor
    10-10-2012 04:58 AM in reply to: lukecoxon3d
    Is this now the official Autocad response now to this issue - after waiting over 2 years for a satisfactory final solution??? We have been doing this work-around for the last 2 years!!
    See post No 10 on this suject
    Regards
    Gary
    Employee
    10-10-2012 01:36 PM in reply to: MOLGRAND
    yes.
    Jarrod Mudford
    Global Services
