AutoCAD Plant 3D
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Getting Fatal Error : Unhandled Access Violation Reading
- Highlight
- Email to a Friend
Reading 0x0000 Exception at f50cd74eh on startup of Plant 3d 2013.
Tried the Repair option. It didn't work.
Reinstalled Plant 3d 2013 after uninstalling everything 2013 related but it didn't work.
The program crashes at startup even if I start only the program and not a project.
Windows / vid card etc are all up to date.
Plant 3d 2012 is still working.
Is there something I should know to fix this ?
Re: Getting Fatal Error : Unhandled Access Violation Reading
- Highlight
- Email to a Friend
I had the same problem, just delete the cache files in the following directroy back to a day your system last worked.
C:\Users\xxxxxx\AppData\Local\Autodesk\AutoCAD Plant 3D 2013 - English\R19.0\enu\GraphicsCache
- Highlight
- Email to a Friend
Thank you, this worked perfectly.
You're a genius ! ![]()
- Highlight
- Email to a Friend
Yes, you ARE a genius. Thanks for this post. Having a the same problem exactly w/ Autocad Architecture 2013. Tried the same repair and reinstall efforts to no avail. This fix did the trick straight away. Not even a reboot needed. Much gratitude. /m
- Highlight
- Email to a Friend
I have the same problem but it happened about 3 months ago so I don't know how many cache files to delete to get rid of this Error. Can I cause more harm if I delete too many cache files? I really would like to use all of the Plant 3D 2013 (student version) features once again ASAP. -thanks
- Highlight
- Email to a Friend
You could just move the file to another folder instead of deleting them. Put them back in if needed.
- Highlight
- Email to a Friend
unfortunatly this did not work and I'm still receiving the fatal error?
- Highlight
- Email to a Friend
i followed the steps u mentioned
my graphicsCache folder was empty though
is there any other way that this issue can be rectified ?
i would really appreciate if you could help me
- Highlight
- Email to a Friend
- Highlight
- Email to a Friend
try deleting the following from the registry (NOTE: MAKE BACKUP OF REGISTRY BEFORE YOU DO ANYTHING)
HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R19.0\
then when you fire up plant again, this part should rebuild itself
You can do it your own way,
If its done just how I say!
[Metallica:And Justice For All:1988]
