• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    AutoCAD Plant 3D
    Active Member
    MAD1975
    Accepted Solution
    Getting Fatal Error : Unhandled Access Violation Reading
    11056 Views, 11 Replies
    08-06-2012 07:00 AM
    Reading 0x0000 Exception at f50cd74eh on startup of Plant 3d 2013.
    Tried the Repair option. It didn't work.
    Reinstalled Plant 3d 2013 after uninstalling everything 2013 related but it didn't work.
    The program crashes at startup even if I start only the program and not a project.
    Windows / vid card etc are all up to date.
    Plant 3d 2012 is still working.
    Is there something I should know to fix this ?
    Please use plain text.
    New Member
    Re: Getting Fatal Error : Unhandled Access Violation Reading
    08-06-2012 08:56 AM in reply to: MAD1975
    I had the same problem, just delete the cache files in the following directroy back to a day your system last worked.
    C:\Users\xxxxxx\AppData\Local\Autodesk\AutoCAD Plant 3D 2013 - English\R19.0\enu\GraphicsCache
    Active Member
    MAD1975
    08-06-2012 09:16 AM in reply to: mtchad
    Thank you, this worked perfectly.
    You're a genius ! :smileyhappy:
    New Member
    08-13-2012 07:16 PM in reply to: mtchad
    Yes, you ARE a genius.  Thanks for this post.  Having a the same problem exactly w/ Autocad Architecture 2013.  Tried the same repair and reinstall efforts to no avail.  This fix did the trick straight away.  Not even a reboot needed.  Much gratitude.  /m
    New Member
    08-17-2012 06:35 PM in reply to: MARKPERKINSON8722
    I have the same problem but it happened about 3 months ago so I don't know how many cache files to delete to get rid of this Error.  Can I cause more harm if I delete too many cache files?  I really would like to use all of the Plant 3D 2013 (student version) features once again ASAP.  -thanks
    Active Member
    MAD1975
    08-21-2012 11:11 AM in reply to: wglavin
    You could just move the file to another folder instead of deleting them. Put them back in if needed.
    New Member
    08-31-2012 03:06 AM in reply to: MAD1975
    unfortunatly this did not work and I'm still receiving the fatal error?
    Member
    10-26-2012 01:54 PM in reply to: MAD1975
    i followed the steps u mentioned
    my graphicsCache folder was empty though
    is there any other way that this issue can be rectified ?
    i would really appreciate if you could help me
    Member
    10-26-2012 01:55 PM in reply to: MAD1975
    Valued Mentor
    Rich.O.3d
    10-31-2012 05:49 PM in reply to: aman.issar1
    try deleting the following from the registry (NOTE: MAKE BACKUP OF REGISTRY BEFORE YOU DO ANYTHING)
    HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R19.0\ACAD-B017:409
    then when you fire up plant again, this part should rebuild itself
    CAD Management 101:
    You can do it your own way,
    If its done just how I say!
    [Metallica:And Justice For All:1988]
